242 transfer case question - JeepForum.com
post #1 of 18 Old 12-31-2013, 09:12 AM Thread Starter
mudder53
Hello, I have the np242j transfer case in my zj and I was out on some trails the other night and after pulling a powerstroke out of a snowbank, I snapped my rear driveshaft up on the slip yoke part of it. Along with that it took a good chunk off the output shaft that the driveshaft slides on to. I have an old np249 that I had originally took out of the jeep with an internal slip yoke on it. Would I be able to replace the np242s ESY shaft with the one from the 249 (ISY). I have a driveshaft for the internal slip yoke already, so that'd work perfect because I wouldnt have to spend any money! :P
mudder53 is offline
post #2 of 18 Old 12-31-2013, 10:05 AM
durango-bob
2006 WK
I don't think that they are the same, but you can try it. Another option that would be a bit easier, but costs more, would be to install a hack and tap sye.
durango-bob is offline
post #3 of 18 Old 12-31-2013, 11:10 AM
Technohead
Replace the TC with a NP231.
-Eric
Technohead is offline
post #4 of 18 Old 12-31-2013, 12:33 PM Thread Starter
mudder53
This is what I have left of the output shaft so don't think a hack n tap would work. Paying the 225 at a local junkyard for a new 242. Will get the hack n tap and new driveshaft for this one down the road
mudder53 is offline
post #5 of 18 Old 12-31-2013, 03:02 PM
durango-bob
2006 WK
Ouch. You should able to drive it in 4wd part time until you get a replacement.
post #6 of 18 Old 12-31-2013, 04:01 PM
Gearhead31
oy vey, that's a big ouch... Yeah, drive it in 4 hi till you can get it dealt with(preferably sooner rather than later if it's going to see a lot of miles). as to your original question, I'm pretty sure it's just different enough that it won't work.
1995 ZJ ltd, 4.0 i6, *cough stock cough* 253,xxx and still pumping strong
1998 Chevy Cheyenne K1500, 5.7L Vortec, mostly stock
*In peace, sons bury their fathers. In war, fathers bury their sons. - Herodotus
Originally Posted by JasonStebbins
We can call it the Whoosh King Catalog System. :D
Gearhead31 is offline
post #7 of 18 Old 12-31-2013, 04:08 PM Thread Starter
mudder53
I had to part time it home quite a ways. I'm just scared because my case has a bad chain clicks constantly. I thought that's what had originally went at first. I'm just biting the pillow and paying the cash for another JY case. Think it'd be easier on my part
mudder53 is offline
post #8 of 18 Old 12-31-2013, 04:11 PM Thread Starter
mudder53
I just could not believe such a chunk of metal would just snap like that... My wheels still might have been spinning while shifting into reverse. It was one of those moments.. I was pretty sure she was calmed down
mudder53 is offline
post #9 of 18 Old 12-31-2013, 04:19 PM Thread Starter
mudder53
I was in snow with the wheels spinning pulling somebody out. There was a lot of tension on the rope so I put it in neutral and it rolled back to release tension and when I went to put it in drive again I heard it snap. I gave it a good second or two in neutral even to roll back so I don't even see why this would have happened
mudder53 is offline
post #10 of 18 Old 12-31-2013, 04:25 PM
Gearhead31
I'm guessing it was on it's way out anyways if it broke in that situation. =/
post #11 of 18 Old 12-31-2013, 05:42 PM Thread Starter
mudder53
Yeah I was just pist that it went out at 5am out in the sticks. I was laying in quite a bit of snow at -35ish windshield to get my driveshaft disconnected from the axle. I guess it was better that it went there instead of out on the highway. Probably would of taken out my exhaust along with the tcase if that were to happen
mudder53 is offline
post #12 of 18 Old 12-31-2013, 11:53 PM
Gearhead31
Oh I bet. Honestly I say you were extremely lucky it went out then instead of on the freeway. Sure it may have been a massive annoyance but it's better than grenading your rear axle when doing 70, eh?
Sent from mobile, where errors are common and I'm too lazy to correct them.
Gearhead31 Hooah!
post #13 of 18 Old 01-01-2014, 12:05 AM
kensnelling
Looking at the rusted metal compared to the clean metal on the shaft I would agree. That shaft had been cracked for a while.
Ken
kensnelling is offline
post #14 of 18 Old 01-01-2014, 06:29 PM
MN59ZJ
Something's not right here. That shaft is 1" of hardened steel, it's not the weak link. The drive shaft tube should have twisted & ripped in two before this happened.
And for the 242 hater's club, that shaft is no different at that failure point than a 231.
Sent from AutoGuide.com App
MN59ZJ is offline
post #15 of 18 Old 01-01-2014, 09:36 PM Thread Starter
mudder53
Ill take a picture of the driveshaft tomorrow and post that. The slip yoke that goes on that tcase shaft had a big chunk missing too
mudder53 is offline
