242 Transfer Case Leaking Where 2 Halves Join - JeepForum.com
post #1 of 9 Old 08-25-2009, 03:47 PM Thread Starter
indianajeep
indianajeep's Avatar
2005 WK
My 242 transfer case is leaking where the 2 halves bolt together on the bottom. I really don't want to take the tfr case down, split the halves and put new sealant on it. Crap - 5 hours worth of gut busting work for $1.50 worth of sealant. Does anyone know of a reliable work-around for this problem?
indianajeep is offline
post #2 of 9 Old 08-25-2009, 03:52 PM
Virmagicus
Virmagicus's Avatar
It's not coming from above and running down right? If it is leaking from around the inside of the bolt you can remove the bolt and squirt some RTV in and put the bolt back in. Not really any other way to fix it besides grinding and welding if it is leaking from the break in the case half.
Jeff
Virmagicus is offline
post #3 of 9 Old 08-25-2009, 04:41 PM
skain8
skain8's Avatar
No band-aid fix for that one. Longshot, but see if any of the main case bolts have worked themselves loose.
'02 WJ: 4.7L, 5", HP44/9", 231HD, tall & skinny KM2's
skain8 is offline
post #4 of 9 Old 08-25-2009, 04:54 PM
WhiteOut
WhiteOut's Avatar
DUCT TAPE FTW!! If its actually coming from the joint the best fix would be to reseal, but try doing the bolt fix first.
WhiteOut is offline
post #5 of 9 Old 08-25-2009, 04:58 PM
blackjack12982
1994 ZJ
Pffftt! The fix is give it to me! I could use another Jeep in the driveway!
blackjack12982 is offline
post #6 of 9 Old 08-25-2009, 05:00 PM
ArloGuthroJeep
Mr. Hyde!
ArloGuthroJeep's Avatar
You don't need to drop the case to fix this. Remove the rear drive shaft. Then a dozen bolts and a set of snap ring and retainer ring pliers and everything pulls apart.
'14 WK2 Limited w/5.7L, ORAI, & Tow Package
ArloGuthroJeep is offline
post #7 of 9 Old 08-25-2009, 08:09 PM
sandman
yep the rear half of the case can be removed with the t-case still bolted up.
1993 Jeep ZJ. 4.0
sandman is offline
post #8 of 9 Old 08-25-2009, 08:37 PM Thread Starter
indianajeep
2005 WK
how many snap rings have to be removed and are they on the rear output shaft?
post #9 of 9 Old 08-25-2009, 09:04 PM
ArloGuthroJeep
Mr. Hyde!
I did it a couple months ago...I believe it was 1 snap ring and one retaining ring...they are on the output shaft.
transfer case leaking tpulliam79 ZJ Grand Cherokee Forum 1 11-05-2009 04:21 PM
leaking transfer case Thelt ZJ Grand Cherokee Forum 4 10-14-2009 11:32 AM
transfer case leaking fluid rufracer ZJ Grand Cherokee Forum 13 03-19-2007 06:59 PM
Leaking from Transfer Case topgun68 ZJ Grand Cherokee Forum 10 11-12-2005 12:37 PM
Transfer case leaking! Please help me out BUNKER ZJ Grand Cherokee Forum 15 06-05-2005 04:03 PM
