242 T-case Swap - 4w and 2w are switched! - JeepForum.com
post #1 of 7 Old 10-04-2009, 12:19 AM Thread Starter
midfifty2
I have a 96 grand cherokee with the 4.0L. I just got a 242 transfer case and put it in. I changed the oil but did not take it apart. My jeep has 2w, 4part time, 4full time, N, 4low. When I tried to drive it turned out the when the shifter is set to 2w it is actually in 4low. And when the shifter is in 4low it is actually in 2w. 4part time and 4full time both give me neutral(unless one of these is just front shaft but I can't tell cuz I don't have the front shaft on cuz it broke). I tried adjusting the shifter underneath by loosening that bolt and let the rod slide through when you shift and then tighten the bolt but it seemed to make no difference.
96 ZJ
4.0L
7" IRO Premium Long Arm
35" BFG km2 mud
DC1 15x8
midfifty2 is offline
post #2 of 7 Old 10-04-2009, 12:26 AM
sandman
is the shift tab on upside down?
1993 Jeep ZJ. 4.0
sandman is offline
post #3 of 7 Old 10-04-2009, 08:35 AM Thread Starter
midfifty2
It is pointing up becuase that's the way I took it off the old one. It looks like it would hit the front drive shaft if I put it down.
96 ZJ
4.0L
35" BFG km2 mud
DC1 15x8
post #4 of 7 Old 10-04-2009, 09:30 AM
Area.3.Fiftyone
The shifter lever on the TC is facing the wrong way.
79' CJ7 - 82' CJ8 - 94' YJ - 96' ZJ
Diagonally parked in a parallel universe.......
Area.3.Fiftyone is offline
post #5 of 7 Old 10-04-2009, 09:50 PM Thread Starter
midfifty2
Well I feel dumb for not figuring this out on my own. But I was confused cuz my old one was pointing up. But probably because the t case exploded and broke into several pieces. Turns out it worked great when I pointed the tab down. Thanks guys.
96 ZJ
4.0L
35" BFG km2 mud
DC1 15x8
post #6 of 7 Old 10-04-2009, 10:23 PM
Virmagicus
Virmagicus's Avatar
Yeah, that was pretty stupid of you.
(j/k)
Jeff
Virmagicus is offline
post #7 of 7 Old 10-05-2009, 06:13 AM
Area.3.Fiftyone
Live and learn. At least you got it figured out.
It never hurts to ask a question, no matter how stupid you may feel.
93 ZJ 249 to 231 T-Case swap Kruzin ZJ Grand Cherokee Forum 14 01-18-2012 09:32 AM
1997 JGC 5.2L, Can the AWD transfer case be switched? skatingbo ZJ Grand Cherokee Forum 11 01-31-2007 12:15 PM
NP 249 NP 242 Swap 94 ZJ 5.2 Trans Case swap / repair? smkarner ZJ Grand Cherokee Forum 1 09-27-2005 05:28 PM
242 vs 249 t-case swap xj51 ZJ Grand Cherokee Forum 3 12-09-2004 07:32 AM
Looking for a swap for the 249 t-case bumpusma ZJ Grand Cherokee Forum 1 10-19-2004 09:17 PM
