242 no 4FT - JeepForum.com
post #1 of 14 Old 08-01-2009, 12:59 PM Thread Starter
skain8
skain8's Avatar
242 no 4FT
Weird issue with my 242. I have 2WD, 4PT & 4LO, but no 4FT. It acts as if in neutral. It's not a linkage problem, b/c I pulled the linkage and manually changed positions and still no 4FT.
Shift fork problem? Is my case toast?
'02 WJ: 4.7L, 5", HP44/9", 231HD, tall & skinny KM2's
skain8 is offline
post #2 of 14 Old 08-01-2009, 01:35 PM
Minivan
Is there a detent for all positions, but it's acting like it's in nuetral in two of the detents?
It's always darkest before dawn... so if your going to steal your neighbors newspaper, that is the time to do so.
Minivan is offline
post #3 of 14 Old 08-01-2009, 01:40 PM Thread Starter
skain8
skain8's Avatar
Yes, detent for all positions, but only the 4FT detent acts like its in neutral.
skain8 is offline
post #4 of 14 Old 08-01-2009, 01:43 PM
nashmd454
nashmd454's Avatar
alright...a thread to watch. I too have had this problem...it starts to engage then pops out.
96' JGC V-8 5.2L ltd.
way too much to list.
Thought for the day:
If GOD gave HIS only son for us...can't we at least give HIM an hour of our time a day.
nashmd454 is offline
post #5 of 14 Old 08-01-2009, 04:46 PM
Minivan
I've looked at your info and it sounds like you have a 242 from the discription of mods, but I'm just trying to make sure it's not a 231. Definately not saying your wrong about the TC.
So it goes into nuetral and acts normally, then when it's in 4FT it also is in nuetral? It has FIVE detents correct, not Four. Is there any grinding noises while shifting with the engine running and trans in gear?
Nash> Yours pops out of gear? If so, it could be either worn syncros or a bent shift fork. Or a combination of the two. Might try lubing all pivot points in the linkage first, to weed out any possible binding issues in the linkage. This could also cause the TC to pop out of gear.
Minivan is offline
post #6 of 14 Old 08-01-2009, 05:28 PM Thread Starter
skain8
skain8's Avatar
Yes, deffinately the 242. 5 positions: 2WD - 4PT - 4FT - N - 4LO. Goes into all positions smoothly, but when taking it out of 4FT (after just revs as if neutral), and try putting it in gear at another detent, there is a fast, higher pitched grinding sound, like rattling a can of marbles until the case locks into position. Neutral is fine.
skain8 is offline
post #7 of 14 Old 08-01-2009, 05:36 PM
unitypunk
this has happened to me once or twice, sounds bad when that grinding sound happens i put it back in neutral and rocked the car abit and tried again and it went into gear fine.
dad said it was dirty/notused enough, thats why it happens.. dont know if i believe him.
have you ever gotten it in to 4FT previously?
Gold 1996 4.0l ZJ Stock 290000 Mi
320wx4 TMA amp, 400Wx2 Audiobahn amp, JLAudio 13.5" W1v2
unitypunk is offline
post #8 of 14 Old 08-01-2009, 08:14 PM
vansskaterfreek
check the fluid for metal particles?
1998 ZJ 5.9L 122k miles - DD, 242 swap, 3.5" RE, 32" BFG M/T, safari rack, roof-mounted lights, custom steel front bumper with hitch reciever, 10k winch :)
2004 WJ 4.7L 107k miles - her daily driver, 2" daystar BB with scorpion shocks.. not too bad! stuffed 265/65/17 General Grabber AT2'S
vansskaterfreek is offline
post #9 of 14 Old 08-02-2009, 11:38 AM
nashmd454
nashmd454's Avatar
thank you very much...I rarely need the 4lo but will def look into that. It is too weird for me to be on here when the only problem I have with my jeep is that the rubber seal that insulates the rear hatch window is old and need to replace...well that and no rear defrost and driver heated seat and air only works in defrost mode and coolant sensor bad. oK SO i DO HAVE SOME PROBS BUT SERIOUSLY...COMPARED TO SOME MINE IS IN GREAT SHAPE. oppss...just saw caps was on.... sorry
post #10 of 14 Old 08-02-2009, 12:09 PM
unitypunk
lol my rear wiper dosent work
sometimes!!
post #11 of 14 Old 08-02-2009, 01:12 PM
Bama_WJ
Bama_WJ's Avatar
http://s11.photobucket.com/albums/a1...t=100_1867.flv
Any of the sounds sound familiar to my video above? You can hear it the best towards the middle of the video. That was back when I had my original 242. It would pop out and gear and just act a fool most the time. Turns out the teeth on the inside were were ate up and chipped. Magnet was COVERED in metal shavings.
Daniel
Current Stable: 2001 WJ, 2006 WK, 2006 TJ
Bama_WJ is offline
post #12 of 14 Old 08-02-2009, 04:14 PM
vansskaterfreek
this is why i say check the fluid, you should be able to tell without breaking the case apart....
post #13 of 14 Old 08-02-2009, 04:42 PM Thread Starter
skain8
skain8's Avatar
Fluid is fine. Doesn't make sense to me, considering 4PT works fine.
skain8 is offline
post #14 of 14 Old 08-02-2009, 05:03 PM
Minivan
Hahaha, that pic remindes me of the rear diff fluid in the 5.9 i had. Same exact color, but in fluid form.
Fluid change turned into a full rebuild.
You might have to spilt the case and take a look. Not that bad of a job especially since it's lifted.
Or you could just tell your self it's got a 231 in it?
Minivan is offline
