242 or 231? help me decide - JeepForum.com
View Poll Results: 242 or 231
242 9 75.00%
231 3 25.00%
Voters: 12. You may not vote on this poll
post #1 of 11 Old 09-21-2007, 03:14 PM Thread Starter
CLNinja
CLNinja's Avatar
i cant decide which one i want to put in my 1993 grand cherokee
i like how the 242 offers Full Time 4wd
tell me the good and bad with each please
i tried searching but the search is messed up it just brings up a white page
Matt
**September 2009 Grand Cherokee Of The Month**
CLNinja is offline
post #2 of 11 Old 09-21-2007, 03:23 PM
Ds4x4
Ds4x4's Avatar
the 242 will probably be more of a bolt in TC then the 231 and is pretty strong while giving you the full range of options.. the 231 can fit with little to no modification depending on years.. the 231 has alot of after market support.. stronger cases, bigger/thicker chains, better shift forks.
if you want the option of fulltime 4wd then go with the 242, if you think you'd want to upgrade the case a little then go with the 231 which still gives you the 2wd option with 4part time and 4lo
1996 ZJ Orvis Edition,V8 5.2L
Tow & Skid Package, FM 40,44a - 3.73, NP249
265/75/16 Destination M/T's, JKS Discos, UC; Dual Intake;Red Top;
OME Stab.; Rustys 2" BB + shocks, xtreme hi-lift, Kennesaw Rear MultiCarrier
Proud To Be A FF/EMT/Police/Military Club Member #15
Ds4x4 is offline
post #3 of 11 Old 09-21-2007, 03:32 PM
Kruzin
Kruzin's Avatar
2009 JK Wrangler
I went with the 231. It's rated stronger, and is 'simpler' (less to go wrong).
I got lucky with mine, and it was a direct swap, linkage and all.
Kruzin is offline
post #4 of 11 Old 09-21-2007, 03:50 PM
UltimatE
Resident Audio Guru
UltimatE's Avatar
I'd go with the 242. I had a 231 in my wrangler and a 242 in each of my Cherokees. I really like having the full time option. As for the strength, both are great transfer cases.
-Matt
White '94 YJ Sport
Green '94 XJ Sport - 57,000 Original miles
UltimatE is offline
post #5 of 11 Old 09-21-2007, 05:31 PM
-Joe-
-Joe-'s Avatar
Its a trick question. If you need a fulltime mode go with the 242 otherwise go with the 231.
I had a 231 but it would not stay in 4wd, it was replaced with a 242 and i think ive needed fulltime mabye once.
Fulltime is more of a novelty for this area.
- Joe -
'95 Jeep Grand Cherokee Laredo I6 4.0L
242TC - Extreme Engineering 2" Front Lift/1.75" Rear Lift - ES9000 Shocks + JKS BPEs
Moog Cargo Control Springs
Magnaflow Converter - Dynomax Muffler
235/75/15 AT Uniroyal Liberator Tires
-Joe- is offline
post #6 of 11 Old 09-21-2007, 10:29 PM
UltimatE
Resident Audio Guru
UltimatE's Avatar
Yup... As for us in the north who have snow and ice, full-time is perfect for days with patches of snow or patches of ice.
-Matt
White '94 YJ Sport
UltimatE is offline
post #7 of 11 Old 09-21-2007, 10:46 PM
Ds4x4
Ds4x4's Avatar
we don't get snow in South jersey........
Ds4x4 is offline
post #8 of 11 Old 09-21-2007, 11:24 PM Thread Starter
CLNinja
CLNinja's Avatar
i live in Colorado
Full Time is very very nice
i think im gonna go with the 242
from what ive read i need medium length input and 23 spline count for it to be a direct fit?
correct me if im wrong
Matt
CLNinja is offline
post #9 of 11 Old 09-22-2007, 08:23 AM
BradMB2004
as long as you use a 95 or older case you can swap the input shafts if needed.
Brad
2004 Wrangler X
2001 Grand Cherokee Ltd.
1997 Grand Cherokee Ltd.
BradMB2004 is offline
post #10 of 11 Old 09-22-2007, 12:23 PM
Eshindi
i like the 242 since it has all those options.
'15 JK Stock | 4k Miles | Bone Stock
SOLD '99 WJ I6 | Claytons LA | 6.5" | HP D44 | F9" | 35's
Eshindi is offline
post #11 of 11 Old 09-22-2007, 04:26 PM Thread Starter
CLNinja
CLNinja's Avatar
so if i get a
-pre 95 np242
-medium length input
-23 spline count
it will bolt right up with no modification? direct swap?
Matt
CLNinja is offline
help me decide thudson331 ZJ Grand Cherokee Forum 3 12-23-2008 08:06 PM
Help me decide michiganmaveric ZJ Grand Cherokee Forum 10 01-22-2008 08:05 AM
You decide Smokestarter WK Grand Cherokee & XK Commander Forum 9 05-02-2007 03:13 AM
Help me decide Chrisj485 ZJ Grand Cherokee Forum 5 02-28-2007 06:12 AM
Help me decide! GrandchampWJ02 ZJ Grand Cherokee Forum 8 10-06-2006 11:46 PM
