Quantcast Was the 231j TC ever used on Grands? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Was the 231j TC ever used on Grands?
Old 06-16-2007, 10:05 PM   #1
SpeedyCat3
Survivor
SpeedyCat3's Avatar
I am starting to round up other parts I might need for the 231j swap, and have not seen it in ZJ's, only on XJ's.
I do have the XJ bezel, but I'd like to find one from a ZJ if it was available.
Thks..
_o o o o_
|_Jeep_|
(OlllllllO)
[] ---o-[]
My 97 ZJ Build
SpeedyCat3 is offline   Reply With Quote
Old 06-16-2007, 10:09 PM   #2
Casper4x4
I got my jeep used and it has the 231 j. Although i do hear its rare from a lot of people...
Alonzo "Casper" Gonzalez
1993 Jeep Grand Cherokee Laredo
4.0L Engine w/ 231 TC
IRO 4.5" Lift on Kumho 31" MT
IRO frnt adj. track bar w/ mount
Bilstein 5150 shocks
JKS Quick Disconnects
JCR 1 Ton steering
Addco Front Sway bar
Flowmaster muffler
K&N air filter
2 Pro Comp 2 KC lights on KOR light bar
Coleman roof rack
Coming Soon! Gears and locker!
Casper4x4 is offline   Reply With Quote
Old 06-16-2007, 10:18 PM   #3
SpeedyCat3
Survivor
SpeedyCat3's Avatar
Wanna sell your bezel...?????
lol...
Thks Alonzo..
At least I know I might be able to get it from the dealer then.
_o o o o_
|_Jeep_|
(OlllllllO)
[] ---o-[]
My 97 ZJ Build
Old 06-16-2007, 10:35 PM   #4
Sporer65
Location: Powder Springs, Georgia/University of Tennessee
93s and I think some 94s had them as options.
Ben
1993 Jeep Grand Wagoneer ZJ V8: Rear Aussie, 3.5" Lift, 31" M/Ts
GA Trail Riders
Sporer65 is offline   Reply With Quote
Old 06-16-2007, 11:17 PM   #5
Casper4x4
hey bud, if only i knew what a bezel was haha... im still new to this auto stuff. I am actually planning on rebuilding my transfer case and use it as a back up just incase the one i have in it now ever decides to go.
JCR 1 Ton steering
Flowmaster muffler
K&N air filter
Coleman roof rack
Old 06-17-2007, 12:47 AM   #6
kirsch98gc6
231s are rare in zjs and were really mostly used in xjs tjs and yjs i believe. The bezel is the shifter assembly you see that reads 2wd 4 hi and 4lo for the 231 and the same plus full time 4wd for the 242
Josh
98 ZJ 4.0 8inch LA, 36 inch Iroks, Ected Lockd-Alloy USA chromo'd HP30, Aussie Lockd-Crown chromo'd-trussed D35, other goodies
kirsch98gc6 is offline   Reply With Quote
Old 08-02-2007, 09:50 PM   #7
LargeFather
I just picked up a 1995 GC Laredo that has the 231J. Is this a desirable transfer case? My tranny man (I'm having to rebuild the tranny, too) has a friend who said he can rebuild it for $450. Should I rebuild it or try to find another?
Thanks,
Scott
1995 Grand Cherokee Laredo, 4.0 liter, auto, 154K miles
1995 Dodge Ram 2500 2WD Turbo Diesel, converted from auto to 5-speed, BOMBED.....
LargeFather is offline   Reply With Quote
Old 08-03-2007, 01:21 AM   #8
SpeedyCat3
Survivor
SpeedyCat3's Avatar
The 231 or 242 both give you a 2 wheel drive option, and part time 4 wheel drive. The 242 also gives you a full time 4 wheel drive, which is not really needed much, unless you see a lot of rain or snow.
Both are good, and many people prefer them over the 249 which is only full or part time 4wd and no 2wd option.
_o o o o_
|_Jeep_|
(OlllllllO)
[] ---o-[]
My 97 ZJ Build
Old 08-03-2007, 01:26 AM   #9
-Joe-
my 95 came stock with the 231, wouldnt stay in 4wd so i swapped in a 242..
- Joe -
'95 Jeep Grand Cherokee Laredo I6 4.0L
242TC - Extreme Engineering 2" Front Lift/1.75" Rear Lift - ES9000 Shocks + JKS BPEs
Moog Cargo Control Springs
Magnaflow Converter - Dynomax Muffler
235/75/15 AT Uniroyal Liberator Tires
-Joe- is offline   Reply With Quote
Old 08-03-2007, 09:47 AM   #10
dpierson
My ZJ has a 231 and it performed awesome in the snow we had this winter.
Dan
Traded 8/9/07
[SIZE=1]Black 94 ZJ Laredo 4.0L 42RE/NP231 Command Trac
Sylvania Silverstars, Alpine CD Head Unit, Pioneer 3-Ways in the Doors, Blacked Out Grill, Kolak Exhaust, Clear Corners, Bilstein Shocks, Gas Tank Skid, Rear Hitch, Hitch Wiring, TC Skid, Hellwig RSB, Military FSB, Brembo Front Rotors, OME SS, B&M Supercooler, RE Tie Rod, Limited Power Leather Seats, 30x9.5 Toyo Open Country ATs, Optima Red Top
Next Mods: Upgrade Battery Cables, Sliders, Black Steelies, 3" Lift, Rear Locker, Bumper, HO Alternator, Winch, Driving Lights[/SIZE]
dpierson is offline   Reply With Quote
Old 08-03-2007, 01:32 PM   #11
weekendsfullofw
I've got the 242 in my 96 ZJ. It's new to me and a little confusing. I have 4 hi part time (lights up rear wheels on console), 4 hi full time (lights up 4 wheels on console), and 4 low part time (lights up 2 wheels on console) This says to me that low range is "part time" ie, I'm in rear wheel drive until the front wheels need to drive. Is that correct? If so, I think it misses the point of 4-low. By the time the front wheels engage, I'm already stuck.
Does the 231 bolt right up to the 42re? Without drive shaft modification?
96 ZJ Laredo. 4.0L, auto, 3.73 gears, stock suspension and 235 tires.
weekendsfullofw is offline   Reply With Quote
Old 08-03-2007, 01:36 PM   #12
RyanZJ
4HI Full Time can be used any time (i.e. FULL time...), even on dry roads. The front and rear driveshafts are not locked together.
4HI Part Time should only be used on slippery roads or dirt roads. The front and rear driveshafts are locked and always spinning at the same speed.
4LO should only be used on slippery roads or dirt roads, when you need gear reduction to "crawl" or you need more power. The front and rear driveshafts are locked and always spinning at the same speed.
Hope that helps.
Ryan
'98 ZJ V8 Limited
'06 WK V8 Laredo
'51 CJ-3A
RyanZJ is offline   Reply With Quote
Old 08-03-2007, 02:06 PM   #13
weekendsfullofw
Please excuse my backward logic.
Old 08-03-2007, 02:08 PM   #14
RyanZJ
It's counter-intuitive, that's for sure.
Ryan
'98 ZJ V8 Limited
'06 WK V8 Laredo
'51 CJ-3A
Old 08-03-2007, 08:32 PM   #15
Redbob
Not so counter-intuitive: you can run full-time in "4 High Full-time"
You can only run part of the time in "part-time"
Redbob is offline   Reply With Quote
Glock Forum
