231 swap into V8 ZJ question - Page 2 - JeepForum.com
post #16 of 21 Old 01-16-2010, 06:44 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
Originally Posted by nwfjarhead View Post
if you swap plugs in the vic it will sense the mode. as far as the gear cut if the replacement t-case has the wrong one you cn order a new one from novak.
how will it sense the 4wd mode with no sensor? ESP?
the place where the 4wd mode switch is on a later tcase has the vacuum disconnect switch in an early 231. the hole is physically different from the later sensors.
Originally Posted by Zew View Post
Not to steal the thread... but i'm actually in the market for either a 5.2 limited or a 5.9 limited. It would be hella nice to convert them to the 231 t-case and not have full time quadratrac 4x4.
Has this swap been done before?
thousands of times.
ratmonkey is offline
post #17 of 21 Old 01-16-2010, 11:03 PM
JrMechanic
thousands of times.
It depends on what year 231 it is and what it came out of. Mine was out of a 94 ZJ and it had the provision for it.
Also, you can replace the vacuum disconnect switch with a mode position switch in earlier 242's and 231's. The thread size, pitch, and depth is the same from the 249 sensor, and both switches operate in the same manor.
Want to swap an NP242 or NP231 into your ZJ? Here's how:
JrMechanic is offline
post #18 of 21 Old 01-17-2010, 02:47 AM
ratmonkey
R.I.P.
ratmonkey's Avatar
i thought we were talking about the 1991 231 the op was using?
post #19 of 21 Old 01-17-2010, 06:49 AM
Technohead
Originally Posted by newfieZJ View Post
Thanks man , 3 yrs on forums , and no one ever mentioned this bolt on case for our 93-95 V8 GC's . The reference was good
Gonna be a tough one to find though . Not many YJ's ever make it to the bone yard here
Just to clarify, 93-95 were the "bad years" for ZJ transfer case swaps; all sorts of different input shaft lengths, gear cut changes, yada, yada, yada. The OP was asking about swapping into a 97 ZJ.
-Eric
Technohead is offline
post #20 of 21 Old 01-17-2010, 06:51 AM
newfieZJ
Originally Posted by Technohead View Post
The gear cut change is irrelevant unless you are swapping input shafts.
ZJ's from 96-98 all have a 0.84" input shaft. The OP said he has a 231 from a 92 YJ. If you check the references, for example Drivetrain.com, you will find that this 231 has a 1.55" input. That same reference will show that 96+ Cherokee 231's all have a 0.84" input shaft. Go find one of those and bolt it in. Done. No worries about gear cut or any of that crap.
I've done some searching (obviously I want one), although the listing states a 1.55 exposed input shaft , it may be a typo . Here's a pic of a 92 YJ 231 . This was pulled from the classified on this forum
Maybe the OP can reply with the measurement on his , I'd like to know before I start pulling cases at the JY.
1995 Orvis build
1988 MJ build
1998 Slate 5.9 build
1998 Platinum 5.9 build
newfieZJ is offline
post #21 of 21 Old 01-17-2010, 12:13 PM Thread Starter
jopolly3
haha yeah that is my NP231 I was talking about...
I was trying to sell it then noticed the 249 was acting up. If it doesn't fit its still up for sale...
Joe
2013 JKU Rubicon 6spd: ARB Dana 44 covers F&R, Expedition One front bumper & swaybar skid, Hella driving lamps, JKS adjustable track bars F&R, MBRP SS off-road exhaust, OME HD springs and shocks, OME relocated SS, Rock Hard 4x4 gas tank skid, Rock Hard 4x4 oil pan skid, Rock Hard 4x4 rock sliders, Rock Hard 4x4 transfer case skid, Spidertrax wheel spacers, Superwinch LP8500 Gen 1
2002 Subaru WRX: Cobb intake, Mishimoto aluminum radiator, Kartboy short throw shifter and bushings
1960 CJ-6: Never ending project rig
Build Threads:
JKUR -
CJ6 -
WJ -
"BFG makes some good rubbers, if they sold condoms I'd buy them" -Owen Horner
jopolly3 is offline
PCM swap question 5.2 spievy79 ZJ Grand Cherokee Forum 1 04-09-2009 07:44 AM
8.8 swap question shdybrady19 ZJ Grand Cherokee Forum 4 04-07-2009 09:04 PM
Yet another 242 swap question ZtotheJ ZJ Grand Cherokee Forum 39 01-08-2009 09:29 AM
242 swap - VIC Question CLNinja ZJ Grand Cherokee Forum 2 03-14-2008 02:45 AM
another 249 to 242 swap question CyberManiaK ZJ Grand Cherokee Forum 8 10-05-2007 05:52 PM
