231 swap into 96zj 5.2 249 - JeepForum.com
post #1 of 5 Old 09-23-2011, 09:35 PM Thread Starter
EdZJ96
so i went to go swap my 2000 XJ 231 into my 1996 zj 5.2 249. and everything slides perfectly into place but my rear driveshaft the 2000 xj rear driveshaft is way to short and my zj driveshaft is about 2 inches to long. so what rear driveshaft do i need? im so dumbfounded because i read on here that the xj driveshaft would drop right in and everything was a direct swap. someone please lead me in the right direction.. thank you
EdZJ96 is offline
post #2 of 5 Old 09-23-2011, 09:39 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
I've never seen that an xj ds will fit. they have a shorter wheel base with a longer trans and engine combo...
Have yours cut down where it needs to be. Most shops charge about 75$ for that service.
ratmonkey is offline
post #3 of 5 Old 09-24-2011, 04:18 AM
Technohead
^ What he said. Cost me exactly $75 the last time I shortened my driveshaft.
-Eric
Technohead is offline
post #4 of 5 Old 09-24-2011, 06:28 AM Thread Starter
EdZJ96
Alright so ill need to have my driveshaft shortened like 2 and a half inches. Correct?
And the only reason I thought the xj shaft would work is because on the thread it said you'll need the rear driveshaft from the doner vehicle. But its all good
Thanks for the help though.
EdZJ96 is offline
post #5 of 5 Old 09-25-2011, 09:46 PM
aaron7
Might need this info as well depending on what 231 I get for mine! Let me know what you had yours cut down to and how it fits!
89 MR2 MK1.5
74 CB360
83 Firebird
79 Dodge Shasta 22' RV
aaron7 is offline
Lifting a 96ZJ? tanner1025 ZJ Grand Cherokee Forum 26 04-21-2011 09:05 PM
axle swap on 96zj bigcarl ZJ Grand Cherokee Forum 12 12-17-2010 06:16 AM
5.9 swap into a 96zj sweetJEEP318 ZJ Grand Cherokee Forum 1 02-05-2010 12:35 AM
96zj 4.0 cuts in and out while driving?! 1sportsdoc ZJ Grand Cherokee Forum 9 04-18-2009 07:05 PM
02 transmisson into 96zj? don birkbeck ZJ Grand Cherokee Forum 1 04-18-2009 04:42 PM
