#1 | |
231 swap completed
My swap is finally finished and road tested. She runs like a dream and it was worth the hard work. All I had to do was swap input gears and change the old seals out and everything bolted right in. Test drove it on some pavement that was a little wet after a light shower and she was very spunky and did a few burn outs too
.I got the case from an auto salvage venue for 150$, they said it came from a 96 cherokee with 100k+ mileage. Tomorrow I am driving out there to get 35$ for the 249 I took out. Quite the savings over what you would pay for a new viscous coupler. And rear wheel drive is so true. The one problem I ran into is that the shift indicator sensor plug does not work with the cars connector. I think I might try and pull the one from the 249 and swap it into the 231, I hope that works. I couldnt help but have a big smile on my face as I drove around in my rejuvenated jeep with its v8 power, maybe its me but the engine even sounds throatier. Anyone considering doing this I would ask you "what are you waiting for?" Also make a note to buy some lock ring pliers because most write-ups forgot to mention them. Napa can get most of the seals, I had a problem getting the rear output from o'reilly's. I am super happy with the results
#2 |
good to hear, ill be doing the swap some time in the next few months
1993 Jeep ZJ. 4.0 |
#3 |
....maybe its me but the engine even sounds throatier.
....um, well -- it's either just you, or you poked a hole in the exhaust while doing the swap. A t-case has no impact whatsoever on engine sound, or performance. On the outside chance that you were just kidding, ...ok. ![]()
"...a long habit of not thinking a thing wrong, gives it a superficial appearance of being right, and raises at first a formidable outcry in defense of custom. But tumult soon subsides. Time makes more converts than reason." Thomas Paine |
#4 |
the 249 sensor will not fit the 231 case
Brad 2004 Wrangler X 2001 Grand Cherokee Ltd. 1997 Grand Cherokee Ltd. |
#5 |
does anyone have more info on this, bought a 231 today and would like my VIC to agree with it.
1993 Jeep ZJ. 4.0 |
#6 |
dont quote me on it but im pretty sure its in here somewhere.
http://www.jeepforum.com/forum/showthread.php?t=685644&highlight=NP231+swap+compl ete i havent read it in a while. |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
