215 tires mess up speedometer? - JeepForum.com
post #1 of 13 Old 12-06-2011, 04:49 PM Thread Starter
ONeil1234
I just bought my jeep about a month ago and the guy just recently installed some 215/70r16's on my jeep. When im on the highway and going 120kph i usually pass all the cars infront of me with my girlfirends accord. But with this jeep im going 120 and everyone is passing me. Just wondering if smaller tires like that can throw of the speedometer and make it seem like im going faster when im not. Also can having smaller tires than recommended in the manual hurt anything on my jeep? Thanks
ONeil1234 is offline
post #2 of 13 Old 12-06-2011, 05:16 PM
KoreaZJ
1994 ZJ
Smaller tires, actual speed is slower than speedo displays.
Put a GPS in there and compare the speed.
Previous owners may have changed the speedo gear.
KoreaZJ is offline
post #3 of 13 Old 12-06-2011, 05:35 PM Thread Starter
ONeil1234
yea thats what i was implying when i said everyone was passing me in my jeep. This guy wasnt the kind of guy to change the speedo gear( im guessing that means rear gear ratio?) Can having smaller tires hurt anything mechanically?
post #4 of 13 Old 12-06-2011, 05:39 PM
PolkaPower
No they are fine. My speedo is 2-3 MPH slower according to my GPS with larger tires. Speedometers are not accurate anyway.
PolkaPower is online now
post #5 of 13 Old 12-06-2011, 05:41 PM
KoreaZJ
1994 ZJ
Won't hurt anything.
My 94 came stock with 215's. Then I changed to 225, then 235, now LT30X9.50
Make sure they're all the same size, especially if you have an NP249 tcase.
KoreaZJ is offline
post #6 of 13 Old 12-06-2011, 06:24 PM Thread Starter
ONeil1234
ok thanks lads.
post #7 of 13 Old 12-06-2011, 08:48 PM Thread Starter
ONeil1234
just a quick question, im doing some minor front end work ( end links, sway bar bushings, shocks) this weekend and i was wondering if i need lube up those bushings with grease before i install them?
post #8 of 13 Old 12-07-2011, 09:04 PM Thread Starter
ONeil1234
I just got done spraying some rust loostener for the bolts on my end links and shocks, and i was looking at the top of the stock shock and there doesnt seem to be a bolt or anything to unscrew up top....is it hiddin up underneath the fender liner?? or do you have to undew the bolt by opening hood and coming from the top through the engine?
post #9 of 13 Old 12-08-2011, 01:05 PM
isenior
I'm on 225 70 16 and my speedo reads 5 mph higher than my sat nav says I'm going.
ZJ97purpleUK
isenior is offline
post #10 of 13 Old 12-08-2011, 01:21 PM
moggie99
This one
Richard Moss
'96 ZJ 4L auto, '95 XJ 4L manual, 2000 Nissan Patrol Y61
In the UK: 1969 MGC GT
moggie99 is offline
post #11 of 13 Old 12-08-2011, 01:23 PM Thread Starter
ONeil1234
k thanks
post #12 of 13 Old 12-08-2011, 02:25 PM Thread Starter
ONeil1234
does anyone have any advice on the easiest way to take off the front left ( drivers side) shock with all the brake fluid lines and resivoir?
post #13 of 13 Old 12-08-2011, 02:31 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
extenstions and wobbles.
ratmonkey is offline
Bigger tires...messed up speedometer...help BigRed4x4 ZJ Grand Cherokee Forum 19 12-19-2009 04:21 PM
Speedometer Calibration options for larger tires? jason915 WK Grand Cherokee & XK Commander Forum 3 11-05-2009 07:33 AM
How much would a size bigger tires mess things up? 12xracer ZJ Grand Cherokee Forum 2 07-29-2008 05:38 AM
speedometer sensor & larger tires stevedog ZJ Grand Cherokee Forum 7 09-02-2006 05:02 PM
Speedometer Calibration for Larger Tires cherokee04 ZJ Grand Cherokee Forum 10 04-08-2005 05:27 AM
