202,000 miles still running. - Page 2 - JeepForum.com
post #16 of 27 Old 08-13-2011, 12:26 AM
caligiuri87
1994 ZJ
i just changed the oil on mine. i have an 94 with 5.2 in it.
has 220000 miles since today yay. never overhauled i believe and very very strong engine. i had kinda same pressure because the prev owner filled it with 5-30.
today i drained and flushed with one quart. then i put in 2 quarts of 10-40 then 1 engine treatment (lucas idea) and then 2 more quarts of 10-40.
i always use valvoline high mileage. and i use baldwin filter. so today did that started up and pressure is little bit higher then 40.
10-30 is what i use on my gf ford escort 4 cyl. so for my k3500 454 i used 10-40. after i did change i let it idle for like 5 or 6 min to get everything oiled up since i let it drain out completely.
caligiuri87 is offline
post #17 of 27 Old 08-13-2011, 01:06 AM
zander21510
My dad's old mechanic sometimes ran the wrong oil (cheap bastard...) and the needle would jump all over the place...i put high mileage oil of the stock weight (10w30) and it usually sits right at 40 at idle, a little higher under accel, and a little more higher at highway speed
zander21510 is offline
post #18 of 27 Old 08-13-2011, 10:54 AM
jaguarjoe
JrMechanic's 100rpm/psi seems pretty true. You don't really need a whole lot of oil pressure to run an engine.
Factory gauges are a joke no matter who's car they're in. Many OEM's use oil pressure switches and a fixed resistor to feed the dummy gauge on the dashboard. It always reads midscale so the typical clueless driver is happy til it reads zero.
Not all oil filters are similar, or at least they didn't used to be. Some had check valve flappers, some didn't. The flapper helps keep oil up in the engine to help with dry starts.
jaguarjoe is offline
post #19 of 27 Old 08-13-2011, 11:39 AM
ratmonkey
R.I.P.
ratmonkey's Avatar
Originally Posted by stormer1092 View Post
it is warmed up my jeep never gets hotter than that. I just did a full service on the coolings system replacing hoses and coolant.
surprised you're not getting a check engine light for the low operating temp.
ratmonkey is offline
post #20 of 27 Old 08-13-2011, 01:09 PM
zander21510
Mine runs at that temp during the winter...and sometimes in this summer when i only drive it for a little while
post #21 of 27 Old 08-13-2011, 01:19 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
must be running a 160* stat or it's stuck open.
post #22 of 27 Old 08-13-2011, 02:14 PM
zander21510
Well I know its not stuck open because I recently did a radiator flush...and it should be all factory...unless (I wouldn't be surprised) my dad's mechanic put a different one in...
Though living in Texas wouldn't a lower Tstat be better?
Sent from my Nexus One using JeepForum
post #23 of 27 Old 08-13-2011, 06:01 PM
corndogduff
I've always thought 180-210 was a good range for a Jeep cooling system. 160 seems awful low.
Duff.
(broken)98 ZJ 5.9
UT Jeepcrew #13
NIGHTCREW
corndogduff is offline
post #24 of 27 Old 08-13-2011, 11:39 PM Thread Starter
stormer1092
1994 ZJ
my jeep has been running that temp since i got it 4 years. Runs fine never throws codes or check engine light?
stormer1092 is offline
post #25 of 27 Old 08-14-2011, 12:43 AM
ratmonkey
R.I.P.
ratmonkey's Avatar
It would most likely run a lot better with a 195 in it. You're still operating in open loop mode.
Hows the fuel economy.
post #26 of 27 Old 08-14-2011, 12:47 AM
zander21510
i get 12-14 city driving 20-23 highway...lately with a even mix of both kinds of driving average 18mpg
post #27 of 27 Old 08-14-2011, 11:36 PM Thread Starter
stormer1092
1994 ZJ
What do you mean a 195? Thermostat right? I still get 16.0 mpg average and around 21-22 on the highway.
How many miles? Mike T25 WK Grand Cherokee & XK Commander Forum 58 09-20-2012 08:02 PM
How many miles do you have on your rig?? 4XHI ZJ Grand Cherokee Forum 63 08-13-2011 06:12 AM
How many miles on your ZJ? atomicflatulenc ZJ Grand Cherokee Forum 24 06-04-2007 01:23 PM
Engine running cool. A/C running hot. nike_sasquatch ZJ Grand Cherokee Forum 4 09-25-2006 10:34 AM
ZJ Stopped running while running? hunt4cleanair ZJ Grand Cherokee Forum 10 05-25-2006 06:21 PM
