202,000 miles still running. - JeepForum.com
post #1 of 27 Old 08-11-2011, 04:38 PM Thread Starter
stormer1092
1994 ZJ
Does the oil pressure seem alright? Its at idle warmed up with 10w-30 oil and a wix oil filter. Was wondering what you guys would recommend to bring it up slightly seems a little low to me.
stormer1092 is offline
post #2 of 27 Old 08-11-2011, 04:41 PM
BlackDaddyZJ
1994 ZJ
looks very low compared to mine, mines generally on the exact opposite side of the guage.i use lucas oil stabilizer when i do my oil changes and that seemed to bring up the pressure a little bit and it has quieted it down a little bit too.
Bob
'94 ZJ
5.2L
IRO 4.5" Lift
35x12.5 Mickey Thompson Baja MTZ's
98 5.9
Restored and daily driven
BlackDaddyZJ is offline
post #3 of 27 Old 08-11-2011, 04:43 PM
jreyes0a39oz
thicker oil, mine has 250k on it everything still originall
jreyes0a39oz is offline
post #4 of 27 Old 08-11-2011, 04:45 PM Thread Starter
stormer1092
1994 ZJ
i usually use high mileage oil but that doesn't seem any higher. I was thinking of using lucas. Does that help with dry starts? Seems like every oil filter I use i get the occasional dry start. Seems like every oil filter company is getting cheaper.
post #5 of 27 Old 08-11-2011, 04:48 PM
BlackDaddyZJ
1994 ZJ
im not surre if it helps with dry starts so im not going to say anything on that. i just use mopar oil filters from the dealership.i tried using k&n filters but i decided to go back to mopar for cost purposes.
Bob
'94 ZJ
5.2L
IRO 4.5" Lift
98 5.9
post #6 of 27 Old 08-11-2011, 09:27 PM
Buzz98zj
Dry start? How would you know?
98 5.9
Buzz98zj is offline
post #7 of 27 Old 08-12-2011, 12:06 AM
BlueDevil
I'd say it's not warmed up - at least by judging from the temp gauge. On the othe hand, looking at the oil pressure gauge seems warmed up. If it's like that when idling, but when you start to drive it goes up, then it's all normal. When engine is warm enough and idling, oil pressure will go down, but will also go up when you hit the right pedal. All of the cars I ever had did that, always.
Beauty is in the eye of the beer holder
* 1994 ZJ (by VIN) with a 1995 engine (PO knows why)
BlueDevil is offline
post #8 of 27 Old 08-12-2011, 02:02 AM
corndogduff
Mine sits there at idle too, as long as you have good pressure while running revs and under a load, you're fine. Remember, this IS a Chrysler electronic part we're talking about, in other words the gauge is a best guess
Duff.
(broken)98 ZJ 5.9
UT Jeepcrew #13
NIGHTCREW
corndogduff is offline
post #9 of 27 Old 08-12-2011, 07:03 AM
JrMechanic
The basic, minimum rule of thumb is 1 psi for every 100 rpm. The average 4.0 could go down to 7-8 PSI at idle and not have any issues. More oil pressure is almost always better, but on a high mileage engine you're doing fine.
If you're worried about it, I would verify it with a mechanical gauge. If it still shows on the low side, try using a higher viscosity oil or just drop the pan and throw a new pump in it, odds are your rear main is leaking and needs done anyways.
A new pump will definitely help but don't expect factory numbers as your main and cam bearings are most likely showing their age slightly.
Want to swap an NP242 or NP231 into your ZJ? Here's how:
JrMechanic is offline
post #10 of 27 Old 08-12-2011, 07:29 AM
Pugulis
Looks fine to me. It goes up when you drive right? Remember the factory gauges in any vehicle (especially older ones) are for show only. The auto industry realized a long time ago that people would pay more money for a gauge than for a light. Even though the gauges are not at all accurate. I guess they're helpful. But I bet you they've caused more problems than they've solved. People will look at a gauge showing low/high temp or oil pressure and because of this start to replace parts that don't need replacing. How many times have you read that someone thought something was wrong because the gauge was showing low or high something. Then after replacing this part and that part and so on, the gauge still showed the same thing. So don't sweat it. It's fine.
[_][]☺[][][]☺[][_] RIP to my 96' Grand Cherokee Laredo 344,700 miles and welcome to my new 2001 WJ
Pugulis is offline
post #11 of 27 Old 08-12-2011, 08:10 AM
JS97ZJ
Just for the record, a filter is just a filter. Unless it is extremely clogged, it 's not going to effect oil pressure. It's job is to hold back unwanted contaminates from wearing out the engine prematurely. So the the more efficient the better.
I was a little surprised when I read this awhile back............
JS97ZJ is offline
post #12 of 27 Old 08-12-2011, 09:30 AM
02Lightning
Just food for thought here, when I changed my oil sender my gauge started reading a mark lower on the gage. So I wouldn't put too much trust what the gage is showing. If you start hearing valve train clatter at idle or the gage reads zero then I would do some worrying.
2001 Jeep Grand Cherokee Laredo 4.0L NV242LD Transfer Case, 42RE, 119,500 miles
02Lightning is offline
post #13 of 27 Old 08-12-2011, 10:03 AM Thread Starter
stormer1092
1994 ZJ
it is warmed up my jeep never gets hotter than that. I just did a full service on the coolings system replacing hoses and coolant.
post #14 of 27 Old 08-12-2011, 10:06 AM Thread Starter
stormer1092
1994 ZJ
You know how your engine makes a noise when you first change the oil and prime the filter? That noise.
post #15 of 27 Old 08-12-2011, 10:12 AM Thread Starter
stormer1092
1994 ZJ
i do not think my rear main is leaking i do not loose any oil what so ever?
How many miles? Mike T25 WK Grand Cherokee & XK Commander Forum 58 09-20-2012 07:02 PM
How many miles do you have on your rig?? 4XHI ZJ Grand Cherokee Forum 63 08-13-2011 05:12 AM
How many miles on your ZJ? atomicflatulenc ZJ Grand Cherokee Forum 24 06-04-2007 12:23 PM
Engine running cool. A/C running hot. nike_sasquatch ZJ Grand Cherokee Forum 4 09-25-2006 09:34 AM
ZJ Stopped running while running? hunt4cleanair ZJ Grand Cherokee Forum 10 05-25-2006 05:21 PM
