2004 WJ Transmission "Buzz" - JeepForum.com
post #1 of 9 Old 12-08-2008, 06:37 PM Thread Starter
WJ_Infinity
All,
I'd like some help on a transmission noise in neutral I have been chasing on my Jeep.
Info: 2004 Jeep Grand Cherokee, 60k miles, 4.0 I6, SelecTrac, 42RE transmission.
Problem: Transmission makes buzzing sound for a period of time (approximately 5 - 10 seconds) when in neutral. The noise is most noticeable when the transmission is shifted from park to neutral but will also make noise when shifted from drive to neutral. The noise will go away after remaining in neutral for a few seconds.
Steps So Far: I have changed the transmission fluid ( Mopar ATF+4) and filter (Mopar) and also verified correct flud level (in neutral). I have also looked at various TSB's regarding a similar issue (TSB#210899) however the TSB doesn't appear to affect 2004 model Jeeps and also states that the noise occurs in reverse, not neutral.
Has anyone else had this issue and found a fix? The Jeep drives and shifts fine but I am concerned there might be an underlying issue.
Thanks!
WJ_Infinity is offline
post #2 of 9 Old 12-08-2008, 07:17 PM
zjilla
thats funny bc every WJ ive rode or driven makes that buzz when shifting from any gear into park. Kinda opposite from what your getting but I thought it was normal. just another noise a jeep makes....Ill shut up now bc im no help
2007 Unlimited Sahara
98 ZJ Limited RHD (British spec)
USAF Military Working Dog Handler
October 2013 JK of the month
My Slowly but surely JK build thread:
zjilla is offline
post #3 of 9 Old 12-09-2008, 01:38 AM
311LJ
311Popo
311LJ's Avatar
The noise is normal. anytime i go from reverse to drive/park or back to revers. but mine only lasts 1 sec or so. it's just shifting into gear.. my friends overland does the same thing. we both have the 545rfe tho. the problem would be maybe if it's buzzing to long. maybe having trouble getting into gear
John
04 TJ Unlimited, GenRight Armor, 37's
89 XJ Laredo, 31's
07 WK Overland, Hemi, Chrome bug deflector
[SOLD] Jimmer 01 WJ *2009 GCOTY*
I ♡ John
311LJ is offline
post #4 of 9 Old 12-09-2008, 12:25 PM
MeWJWifeZJ
This is a completely normal sound, it happens whenever the transmission shifts, usually you can't hear it due to road noise, but it's normal.
Praise to a Child is like Sunlight to Flowers
Traded away the WJ to get a commuter
We finally got another Jeep after 5 years without. Too bad it's ALL stock.
MeWJWifeZJ is offline
post #5 of 9 Old 12-09-2008, 01:29 PM
311LJ
311Popo
311LJ's Avatar
ya but if it's buzzing extra long it might not be "normal"
John
89 XJ Laredo, 31's
I ♡ John
311LJ is offline
post #6 of 9 Old 12-09-2008, 05:33 PM Thread Starter
WJ_Infinity
Thanks very much to everyone for their responses. I'm concerned that the noise lasts for more than just a second.
The noise is loudest after first shifting in neutral and then slowly reduces in volume until you can't hear it. The transmission bellhousing was slightly damp but I haven't removed the inspection cover to see if the pump may be leaking.
Any ideas or suggestions to troubleshoot this?
Thanks again!
post #7 of 9 Old 12-10-2008, 10:27 AM
wjjeepman34
IIRC the "buzzing" noise has something to do with the solenoids heating up or something along the lines of that. You may have bad solenoids, or in simplier terms, a partially bad trans.
04 WJ 4.7 V8-Fully loaded, K&N FIPK, V-force muffler, Duratracs, OME HD coils, Bilsteins, JKS track bar, JKS quicker disconnects, IRO aux mounted SS, Rear sway bar delete, Custom winch bumper.
wjjeepman34 is offline
post #8 of 9 Old 12-13-2008, 07:08 AM
zjilla
Im going to quote my self, can I do that? neways: x2 the noise being longer than just a second or two. that might be a problem. (the noise I thought was normal only lasted for a second or two)
zjilla is offline
post #9 of 9 Old 01-14-2014, 10:41 PM
ShadowTek
I also have an 2004 4.0 with the 42re, and mine does the exact same thing.
It only does it when it's cold, and it tends to be louder the colder it is outside. It usually goes away completely once the fluid has fully warmed up, and it never makes a noise in the summertime.
I've changed the fluid with ATF+4, checked the fluid level peroperly, replaced the filter, and adjusted both bands, but it's had no effect on this noise issue.
I bought it when it was around 110k, and it buzzed a little, but not bad. Now, at 150k, it seems to be a little louded sometimes, and it was louder than I've ever heard it before when I started it recently on a cold day.
ShadowTek is offline
2004 WJ : "Moaning" sound when in reverse JustSomeDude ZJ Grand Cherokee Forum 2 05-25-2009 07:27 PM
Another "clunk" thread - ignore the noise? (2004 WJ) JustSomeDude ZJ Grand Cherokee Forum 5 03-30-2009 10:15 AM
2004 Jeep Limited: (AZC "manual mode") question 2tone93zj ZJ Grand Cherokee Forum 3 02-23-2009 09:39 PM
2004 Lerado - Hood Lift Air-Loaded "things" now working lbi2000 ZJ Grand Cherokee Forum 2 12-15-2008 06:39 AM
2004 Jeep Grand Cherokee "Special Edition"..... platinum5.9 ZJ Grand Cherokee Forum 7 08-16-2006 08:30 AM
