2004 wj spark plug and coil pack advice? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > 2004 wj spark plug and coil pack advice?
HMF Fabrication 50" Light Bar Mounts for CJ/YJ Made IIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineRuffstuff XJ Unirail Channel Reinforcement....
Unread 09-19-2009, 07:34 AM   #1
xxFLETCHxx
Looking to change my plugs and pack out. Jeep has just under 74,000miles one it. What are your advices on what products to run with my jeep?? I saw alot of different suggestions.....just not sure.... i have a 2004 4,7l v8
2004 JEEP GRAND CHEROKEE
4.7L V8
xxFLETCHxx is offline   Reply With Quote
Unread 09-19-2009, 07:38 AM   #2
Turbonut
Original plugs and why change the coils if no problems?
http://www.wjjeeps.com/service/sparkplugs.htm
CAUTION: The standard 4.7L engine uses copper core ground electrode spark plugs, they must be replaced with the same type/number spark plug as the original. If another spark plug is substituted, pre-ignition will result.
Turbonut is offline   Reply With Quote
Unread 09-19-2009, 07:41 AM   #3
xxFLETCHxx
good point, that I'll leave alone than......could i run these plugs.........Been reading, it has the same product number as the Mopar ones except it has RC instead of MP
Champion Spark Plug
Part No. 3340
PLATINUM POWER; RC7PYCB4
4.7L V8
Unread 09-19-2009, 07:52 AM   #4
Turbonut
Champion Spark Plug
Part No. 3340
Get the Champs RC12MCC4 or #439, unless it is a HO, then get the RC7PYCB4 or #3340.
You will see no difference in performance or mileage, so stick waith the OE plugs.
Unread 09-19-2009, 11:27 AM   #5
michiganmaveric
Got Beer?
michiganmaveric's Avatar
2011 JK Wrangler
I am running the champion single platinums right now. I got them at NAPA and because the cost difference was not that much I went wiht the platinums. The only reason I did is because I don't change my plugs but about avery 75,000-100,000 miles. No real proformance difference.
Leave the coil packs alone. I have over 235,000 miles on mine with no problems.
Previous Jeeps: 84 CJ7 (A True Jeep), 2000 XJ (163,000 Miles/Totaled (Pictures of wrecked Jeep in gallery)), 2004 WJ (parting out die to major electrical issues)
If you don't have time to do it right the first time, how do you have time to do it over.
Lifetime member #13
www.militaryjeepers.com lifetime member/airforce26yrs
2011 Tango/Mango JKU
michiganmaveric is online now   Reply With Quote
Unread 09-19-2009, 05:40 PM   #6
wj03grandy
2003 WJ
Use Original Plugs Or Equivilant !!!!!!!!!!!
wj03grandy is offline   Reply With Quote
Unread 09-20-2009, 09:57 PM   #7
sprocket1200
standard plugs and leave the coil packs...
sprocket1200 is offline   Reply With Quote
Unread 09-20-2009, 10:59 PM   #8
the88thpianoman
the88thpianoman's Avatar
2003 WJ
That is all.
WJ front drive shaft and fuse panel for sale
2003 WJ in Jeep Green Metallic, 4.0/242/4.10's. 4" Teraflex springs w/ RE monotube shocks and IRO short arms, cheap intake w/ amsoil filter, 2.5" hi flow cat and back exhaust, lots of lights and other misc crap.
Check out my build thread here: Life lessons and budget build
the88thpianoman is offline   Reply With Quote
Unread 09-21-2009, 12:46 AM   #9
WiCkeDuDe
WiCkeDuDe's Avatar
I wouldnt let a copper core spark plug go for more than 30k at the most. Not sure how often you like to change them. Im am actually running the ngk iridiums on my 4.7 and I have had no problems at all. Ive heard some like to use autolites in their jeeps as well. I just run ngks on all my stuff so I did it on the WJ as well.
WiCkeDuDe is offline   Reply With Quote
