2004 Overland Build - Need input! - JeepForum.com
post #1 of 13 Old 05-09-2008, 09:54 AM Thread Starter
steevireno
Hi guys,
I have a 2004 Overland where the lease is reaching its maturity. The buyout is so good and the condition of the vehicle is so nice I don't think I can let it go. I completed my TJ build in 2007 and am looking to take on another project.
That said, I have been researching lift kit/tire combos and am not coming up with great information. My goal is this:
- lift the Jeep enough to clear 33's
- decent articulation when the sway bars disconnected
- maintain stock or close to stock ride quality if at all possible
- avoid death wobble
- avoid drive shaft vibration
I have seen some sites state that a 4" coil kit will work with modification to the bumpers. I plan on replacing at least the stock front bumper with a winch-friendly one.
Thoughts please?????
steevireno is offline
post #2 of 13 Old 05-09-2008, 11:09 AM
JayIV
JayIV's Avatar
You'll need a 4.5-5.5'' lift. Clayton's is my number one suggestion. You can get your coils from IRO, they ride way nice.
It'll have great articulation, the WJ's can flex like mofo's.
I liked my MX6s for ride quality, however, the do limit flex about 1 1/2'' compared to a shock of similar size.
DW usually doesn't happen with long arms, thats why I suggested Clayton's. However, in order to avoid it, you'll need to make sure your front end is nice and tight, and none of the steering components are very worn.
As long as you have a double cardan front shaft, and not the CV one (likely you'll have the DC shaft), you'll be good up to 6.5''. Just set your pinion angles correctly.
2004 Overland
JayIV is offline
post #3 of 13 Old 05-09-2008, 11:23 AM
IronManVa
I AM IRON MAN
IronManVa's Avatar
setup in my sig works for me. wheels great... I had death wobble til I put on a dual SS... it was not bad but every time I disconnected to wheel it seemed to pop up...
some pic threads
http://www.jeepforum.com/forum/showp...&postcount=116
http://www.jeepforum.com/forum/showp...&postcount=119
http://www.jeepforum.com/forum/showp...&postcount=133
2004 Overland 4" KOR/IRO Long Arms
2004 Rubicon 6.5" RK X-Factor LA on 35" KM2s 488s Tom Woods & plenty of BTF Armor ORO U-Turn system
1995 Jeep Orvis 4.0 3" Rancho
Virginia Beach ...
Off season Jeeper Deals
IronManVa is offline
post #4 of 13 Old 05-09-2008, 11:24 AM Thread Starter
steevireno
Thanks Jay. Are you using the IRO colis? Would you compare the ride of your Jeep with a 6.5 lift to that of close to stock?
post #5 of 13 Old 05-09-2008, 11:37 AM
Diehard
Diehard's Avatar
After you lift it, put better offroad tires, unless you do 2 sets of tires, the ride will not be like stock. Mine is at 3.25", (2.5" pucks and UC springs), with the MX-6 shocks and 265/75/16 10 ply Maxxis Bighorns. The ride is a little stiffer, but you would have to expect that. It was my DD till last month. I laid it on its side and now after its fixed I'll be using it as an offroad vehicle. I'll be looking at long arms also, but only a 4" lift, (I have a height restriction since I'm in a wheelchair and getting in and out has to be considered). Good luck on your build and post up some pics.
2004 GC Spec. Edit. V8 4x4 Quadra-Trac II. Bright Silver Metallic Clear Coat, 4" lift, RE shocks, adj. JKS CAs all around, 265/75/16, ProtoFab winch bumper, Vortex 10,000 lb. winch, dual OME steering stabilizer, Rockyroad rockrails, skids, JKS Discos. Addco front & rear sway bar, & Aussie locker.
Diehard is offline
post #6 of 13 Old 05-09-2008, 11:53 AM Thread Starter
steevireno
Good point on the tires... I probably won't keep two sets as I do not intend this to be a daily driver, however want to be comfortable on extended trips with the family for an off-road excursion - the nearest park for me 90 minutes away and my wife and I don't to be bouncing around to and from the ride. I have Truxxus Tires on my Wrangler which are fairly quite and priced well which I will probably mimic on this set up. I plan on using the stock 17" rims - not sure how wide I can go on these, but will use a spacer at first if I need some extra wheel spacing.
I am glad to hear that I can get away with a 4-4.5" lift with 33's - I didn't want to go up too high.
Sorry to hear you laid yours over.
post #7 of 13 Old 05-09-2008, 12:13 PM
Diehard
Diehard's Avatar
I wasn't even offroading it, but at least they didn't total it.
Diehard is offline
post #8 of 13 Old 05-09-2008, 12:32 PM
nierace
nierace's Avatar
2003 WJ
It will ride nothing like it does when stock. Even with LA's they soften the ride, but its not even close to stock, who ever tells you otherwise hasn't gone back and forth from driving their lifted WJ to a stock one.
It will ride similar to a 3/4 pickup truck.
You can fit 285/75R16's on 4" and some trimming, I bet you could do it with 3" of lift and a bit more trimming, and at 3" your keeping your control arm angles fairly mild to retain ride quality and keeping your pinion angles in good shape.
IMO if you already have a trail rig its silly to lift your overland especially with the fore casted gas prices
Nickerdoodle
03 WJ 4.7 242HD Kolak/IRO 5" Clayton LA's
35" BFGoodrich KM2
North East Offroad Club
nierace is offline
post #9 of 13 Old 05-09-2008, 01:01 PM Thread Starter
steevireno
I can tolerate the ride of 3/4 ton pickup - I am trying to stay away from the ride of a go-kart.
You raise an interesting point - considering I would be pulling off the front bumper and replacing it with a winch friendly after market version and could potentially do the same for the rear do you think I could actually get away with a 3" lift??? Is it the bumpers that are the concern or the fenders?
post #10 of 13 Old 05-09-2008, 01:03 PM Thread Starter
steevireno
By the way, you have 03 ZJ in your signature - shouldn't that be WJ?
post #11 of 13 Old 05-09-2008, 01:07 PM
FooK
FooK's Avatar
I think the first thing you need to do is downgrade the RB1 navigation cd player it has to a single disc more basic one...like mine...
I'll trade you, that will cure it!
Haha
Seriously though, I like the looks of the Teraflex 4" system, minus the pitman arm and track bar. I'm probably gonna run that on my 02 WJ, along with a JKS adjustable track bar, and then Kevin's stabilizer relocator. I think it will be a good setup. We run their 4" system on our company JK. Rides very nice.
Jason Roy - Marketing Director at WP
Driver #1724 Team WP Jeepspeed
Co-Driver #36 ERS Rally Team
FooK is offline
post #12 of 13 Old 05-09-2008, 01:36 PM
nierace
nierace's Avatar
2003 WJ
your going to rub on the fenders up front without trimming unless you dont wheel it, otherwise bumpers are only place you'll really rub. In back with extended bump stops out back you should be ok with 33's.
Nickerdoodle
35" BFGoodrich KM2
nierace is offline
post #13 of 13 Old 05-09-2008, 02:13 PM
JayIV
JayIV's Avatar
Hell no lol. But for a vehicle lifted 6.5'', it sure rides damn nice.
I'm using IRO coils with Clayton's LAs, JKS tracbar, any many, many other various parts.
2004 Overland
JayIV is offline
Overland or Overboard?? Is it worth buying a 2004 Grand Cherokee Overland MIDDAWG2 ZJ Grand Cherokee Forum 21 12-27-2009 01:13 AM
2004 Overland frytzz ZJ Grand Cherokee Forum 4 05-21-2006 08:12 AM
How much should I pay for a 2004 GC Overland x67934 ZJ Grand Cherokee Forum 5 11-18-2005 05:11 PM
2004 Overland. akarusso WJ Grand Cherokee Forum 1 04-13-2004 07:39 AM
2004 Overland Flyguy WJ Grand Cherokee Forum 1 04-28-2003 08:02 AM
