2004 Lerado - Driver Power Lock & Power Windows - JeepForum.com
post #1 of 4 Old 10-19-2008, 06:03 PM Thread Starter
lbi2000
2 weeks ago i noticed that my driver door power lock was not working, but sometimes it would work. I would have to go over to the passenger door and hit the power lock/unlock.
Today... more problems... i noticed that none of the power lock or windows worked on the drivers side... and they didn't work on the passenger side either! Then... 30 mins later everything worked fine.
Anyone know the cure/fix to this problem.. has anyone had this before ?
Thanks
lbi2000 is offline
post #2 of 4 Old 10-19-2008, 06:32 PM
Kruzin
Kruzin's Avatar
2009 JK Wrangler
It's usually 1 of 2 things that cause this.
1. The master window/lock switch in the driver's door is bad.
2. There is a broken wire in the harness between the body and driver's door.
'09 JK Rubicon
'01 XJ Sport
'10 Fusion
Kruzin is offline
post #3 of 4 Old 10-19-2008, 07:58 PM
kjcdc090385
x2 on the wire...I had the same problem and I actually had to have the whole harness replaced b\c of melting wires
kjcdc090385 is offline
post #4 of 4 Old 10-20-2008, 03:58 AM Thread Starter
lbi2000
Where can i get the driver door switch part ?
Thanks for the reply... is there a recommended online way to buy jeep parts ? I want to inspect the door and wires and replace the switch myself...
lbi2000 is offline
93 5.2 ZJ, Driver power lock won't work xKingSizex ZJ Grand Cherokee Forum 3 11-09-2009 04:41 PM
~ Power windows and door lock issues ~ SouthSeaPirate ZJ Grand Cherokee Forum 8 08-20-2009 10:27 PM
Power windows/locks/keyless lock doesn't work matt21484 ZJ Grand Cherokee Forum 22 04-21-2009 08:57 AM
Driver Door Power Lock Again! FPKites ZJ Grand Cherokee Forum 19 01-17-2005 08:19 PM
Driver Door Power Lock - 3 Strikes, I'm out - Any sparkies out there? FPKites ZJ Grand Cherokee Forum 7 12-20-2004 12:34 PM
