2004 Grand Cherokee rotors - JeepForum.com
post #1 of 3 Old 10-24-2007, 05:53 PM Thread Starter
Markwvj
I have a 2004 Grand Cherokee that seems to warp rotors if you look at them cross-eyed. I am going on my third set of rotors in 36 thousand miles (as you can see I am not hard on my Jeep) I know there is a tech bulletin on the 2002 for rotors but I can't find any on my 2004 relating to brake rotors. I have a friend who has a 2004 as well and he is experiencing the same issues. Any help out there would sure be appreciated, you can email me direct at: markh42003@yahoo.com if you have any input. BTW it is the Columbia edition 4.7ltr H.O. thanks in advance.... Mark
Markwvj is offline
post #2 of 3 Old 10-24-2007, 09:32 PM
Flyusaf2002
Hey Mark - this is a really common problem, even for you new WJ's that have the Akebono Calipers. Its a combination of uneven pressure and excessive temperature that causes the rotors to wear out. If you search on the forum, you'll see a ton of threads regarding the problem.
Basically - stop buying stock rotors. A lot of people have luck with the Brembo replacements. Some other guys have had luck with the discount brakes at Brakeplanet.com.
If you want to fix it right - Talk to Nick and buy his Stillen Rotos and Metal Matrix pads. You can get him at Kolak@aol.com
They aren't cheap, but supposedly they're the best.
Go over to www.wjjeeps.com, go into the expanded index, and start looking around at all the information on the brake problem - you're not the first!
Good luck!
Andy
(PS...I went the cheap route with Brakeplanet drilled and slotted....they haven't failed yet...but it hasn't been that long!)
STEEL CITY JEEP CLUB MEMBER # 17
99 Green TJ "Gracie" SOLD
2001 Red WJ "Ginger"
Flyusaf2002 is offline
post #3 of 3 Old 10-25-2007, 05:48 AM
georged
I think there should be another class acion suit to cover the 2004 models.
georged is offline
Rear brake rotors stuck on 98 Grand Cherokee Luke49783 ZJ Grand Cherokee Forum 3 09-13-2008 07:51 PM
2004 Jeep Grand Cherokee Rotors cdn_grl ZJ Grand Cherokee Forum 2 10-15-2007 07:46 AM
2004 Grand Cherokee jclax ZJ Grand Cherokee Forum 1 05-26-2007 10:11 AM
Need your help: Removing Calipers from Rotors on 1999 Grand Cherokee 4x4, front cjdietzman ZJ Grand Cherokee Forum 4 07-01-2004 10:24 AM
'99> Grand Cherokee Brake Rotors gsvette WJ Grand Cherokee Forum 5 06-14-2002 10:29 AM
