2004 Grand Cherokee front end shakes during braking - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > 2004 Grand Cherokee front end shakes during braking
WJ Modular Recovery & Bull Bar Relocation PackagesRough Country Jeep Suspension Deals at Rockridge 4WD!Steinjager TJ tube doors
Unread 05-04-2009, 06:51 AM   #1
ashbrooke
I have a stock 04' Grand Cherokee Limited Edition w/Quadtra Trac II 4x4, with 90,000 miles.
My problem is whenever I apply the brakes, the front end and steering wheel shake very bad. This was happening with the older tires and new ones I had put on last summer. Someone suggested that since the brakes haven't been serviced for quite a while that maybe the front disc have worn unevenly.
Any suggestions would be appreciated.
Thanks
ashbrooke is offline   Reply With Quote
Unread 05-04-2009, 07:08 AM   #2
ArloGuthroJeep
Mr. Hyde!
ArloGuthroJeep's Avatar
Classic warped rotors. There are a couple options. Either replace with the OEM rotors or what ever your local parts store has (replace the pads at the same time), or pick up some Brembo rotors online (from www.tirerack.com for instance) and those shouldn't warp ever again. Or if you want a performance upgrade, check out Stillen rotors (There is a great vendor on here - you can email him at kolak@aol.com - tell him youre a JF member and get a discount).
'14 WK2 Limited w/5.7L, ORAI, & Tow Package
ArloGuthroJeep is offline   Reply With Quote
Unread 05-04-2009, 08:28 AM   #3
walter_da_jpr
4.0 Piston Skirt Victim
walter_da_jpr's Avatar
X2
I have brembo oem replacements. They have been perfect for years.
WALTER
walter_da_jpr is offline   Reply With Quote
Unread 05-04-2009, 03:43 PM   #4
ashbrooke
Thanks for the info, I tried finding Brembo rotors but two places I talked to said they didn't make them for Cherokees' after 1999.
No problem though, I'll just get another aftermarket brand. I decided to get the Hawk disc pads though. I've got them on my Wrangler and they seem to last forever.
Unread 05-04-2009, 03:50 PM   #5
walter_da_jpr
Well, rotors for a 99 would work. Regardless of what brand of aftermarket rotor you buy, make sure that they are a single cast rotor, not two pieces like the stock rotors. That is a key to minimizing warpage.
WALTER
Unread 05-05-2009, 04:20 PM   #6
ashbrooke
Thanks for that info.
I tried tirerack.com but they only had one Brembo rotor in. I'll have to look around.
Unread 05-08-2009, 03:48 PM   #7
ashbrooke
More problems discovered......Help!
Well I've got the brakes disassembled but I noticed the slide pins on the caliber bracket don't slide in and out, so I ordered another set.
Has anyone had a problem with them being seized up?
Also, I think I've found another problem on the right side. When I rotate the wheel by hand, I can hear a grinding sound. I hope it's just a bearing, has anyone had this problem also.
Unread 05-08-2009, 09:03 PM   #8
BlackShuck
Are these the same slide pins that I've heard will come when buying new pads? At lease I've heard the stillen metal matrix pads come with new slides/clips or whatever.
01 WJ Spec. App. Laredo. Retrofitted with Akebono calipers; Stillen Sport Rotors; Reese Class III Hitch; and a ZJ Front Drive Shaft
Save yourself time, money, and a lot of frustration by NOT shopping at JcWhitney!!
Utah Jeep Crew #8
FS: Rear wind deflectors || || Stock OEM Air Box Set Up
BlackShuck is offline   Reply With Quote
Unread 05-09-2009, 06:30 AM   #9
ashbrooke
I had to order these separate at the dealership, I'm picking them up today. If I can upload pics, I'll do that later today. I just hope I can get the old ones off without too much trouble, I assume just a wrench and a cheater bar is all that is needed.
Of course, I see now that my Haynes Repair Manual for 2004 does not have the same front brake assembly as what is actually on my vehicle. Does anyone have a close-up picture of the clips for the pads?
Unread 03-10-2014, 06:22 PM   #10
J_Tronco
I have a 2001 Grand Cherokee Limited 4.7 V8 AWD. It shakes violently with braking at a high speed. I researched different things it could be. I did not think it was the rotors because I recently had them turned. Some people said its the steering stabilizer or tie rod ends. I replaced the tie rod ends first and it did not fix the problem. However, they were very worn out and needed to be replaced anyway. I have ordered a new steering stabilizer and I am going to go ahead and order new rotors and pads too. Hopefully, this will fix the problem completely.
J_Tronco is offline   Reply With Quote
Unread 03-10-2014, 07:12 PM   #11
porrsher
1994 ZJ
1993-1998 zj
1999-2004 wj
1994 Hunter Green ZJ 5.2L Quadratrac
228k Miles, 2" BB.
2002 Slate Grey Grand Cherokee Overland
161k Bone Stock
2008 Black JK Sahara Unlimited (Love it!)
porrsher is offline   Reply With Quote
