2004 Grand Cherokee 4.0 will crank but won't start... - JeepForum.com
post #1 of 14 Old 11-03-2009, 12:40 PM Thread Starter
rspi
Long story or short. Well, I'm at work so here is the short...
I have a 2004 Grand Cherokee Laredo with 93,880 miles on it that will not start. I parked it at the office, went to leave 4 hours later and it will not start. It cranks well, but won't turn over. I can not hear the fuel pump.
I hooked up my cheep OBD-II code reader and I get an error message that it will not link to the computer. So I ordered a "programmed computer" and it still does not start. Just cranks and cranks and cranks...
What should I try next???
rspi is offline
post #2 of 14 Old 11-03-2009, 01:19 PM
mhems001
2015 JK Wrangler
have you check your vitals, fuel air and spark, to see what in general is keeping it from running
mhems001 is offline
post #3 of 14 Old 11-03-2009, 01:48 PM Thread Starter
rspi
Well, I thought hooking it up to a OBD-II was checking vitals. I hear no fuel pump...
rspi is offline
post #4 of 14 Old 11-03-2009, 04:08 PM
jeep210
When you first turn your key on you should hear the fuel pump run, in the fuel tank, for a few seconds. If you don't hear it, check your ASD relay and the Fuel Pump relay. You can swap them out with similar. Or test them for normal operation. That is the first step.
jeep210 is offline
post #5 of 14 Old 11-04-2009, 10:08 AM Thread Starter
rspi
Oh, forgot to mention, I did replace the fuel pump relay. Actually, I have replaced it twice in the past 6 months because I have a problem with the battery terminals having corrosion build up (that was NOT visable). So I figured it out when I replaced the battery.
I'll try replacing the ASD relay (which ever one that is). If that does not work, I will replace the crank shaft sensor (just picked one up from NAPA).
rspi is offline
post #6 of 14 Old 11-04-2009, 10:13 AM
mhems001
2015 JK Wrangler
before you go throwing more guess parts at it
-See if you have spark at the spark plugs
-See if you have fuel at the fuel rail
mhems001 is offline
post #7 of 14 Old 11-04-2009, 01:04 PM Thread Starter
rspi
Ok, I swapped the relays out, still no start. So I want to install this Crank Shaft Possition sensor... Where is it? I hope it's not between the motor and the fire wall. If so, how in the heck do you replace it???
rspi is offline
post #8 of 14 Old 11-04-2009, 02:22 PM
JesseOR
Go down to an autoparts store and pick up a Haynes manual. It will tell you where and how to test everything is located. It also has a TROUBLE SHOOTING section. DO IT BEFORE you just start dumping money into repairs that may not be the root of your problem
-Jesse-
GO DUCKS!
www.facebook.com/jesse.whitehargrove
JesseOR is offline
post #9 of 14 Old 11-04-2009, 02:30 PM
mhems001
2015 JK Wrangler
I second that
mhems001 is offline
post #10 of 14 Old 11-04-2009, 04:34 PM
jeep210
I'm with the other members here. Do not throw parts at this trying to fix it. It gets expensive and you may not fix a thing. A Haynes manual will help.
No start problems are related to a fuel or ignition problem. Try cranking it over and check for a spark at the plugs or coil. If you have a spark, the CPS is not the problem. When you turn the key to on, you should hear the fuel pump run for a couple of seconds. Try turning you key on and off but do not try to start. Do this a couple of times then try to start. It could be a fuel issue.
The CPS is a pain to change. On a 4.0 it is on the drivers side bell housing on the transmission. On the V-8's it is on the passenger side.
Ok, I just saw that you have a 2004 and you may have a distributorless ignition. I think you have coil packs for each plug. I could be wrong. Not sure how to check for spark with that ignition. Maybe someone can comment on it. I am not sure.
jeep210 is offline
post #11 of 14 Old 11-05-2009, 06:20 AM Thread Starter
rspi
And the winner is (drum roll please), Crank Shaft Position Sensor.
Again, the symptoms:
1. Will not start.
2. Can not hear the fuel pump when you try to start.
3. Can not read the computer with the OBD-II code reader. Will not connect or communicate.
4. (Not sure about spark or fuel - my guess is have spark / no fuel).
Not a DIY job, just not enough space for me to reach the part to replace it. A local Jeep mechanic was kind enough to use my NAPA part and did the job for $113.
rspi is offline
post #12 of 14 Old 11-05-2009, 07:50 AM
xJoshxx
2012 WK
1. Will not start.
No Ob2 thats bad.
Sold4" Hybrid lift TeraFlex coils IRO Adjustable LA's Jks tracbar 1.25spidertrax spacers 265/75/16 Dura-tracs
Originally Posted by moPowered View Post
The SRt-8's are a liberty design.
2011 WK2 ORA2 sold
2012 WK2 SRT8 - Current
99 WJ Limited Lifted.
2001 WJ stock 4.0 304k miles
xJoshxx is offline
post #13 of 14 Old 04-29-2017, 08:04 PM
stuckcranking
my jeep had a problem stalling at idle (stop lights) i changed the crankshaft position sensor, would crank but no start after that, i changed out the cam shaft position sensor as that is the new code that came up on the obd 2. still crank no start, changed out the coil rail, and 2 injectors that had cracked housings, still crank but no start. now where do i go?
stuckcranking is offline
post #14 of 14 Old 04-29-2017, 10:31 PM
SAR-Swimmer
Filling out your Jeep profile would be a good start, so we'll know what you have.
SAR-Swimmer is offline
1994 grand cherokee wont crank or start ekelley1985 ZJ Grand Cherokee Forum 15 07-12-2012 09:15 PM
My 2004 grand cherokee wont start! bringnthenoise ZJ Grand Cherokee Forum 8 11-03-2009 12:28 PM
97 grand cherokee will crank but not start and im at my wits end pla4kps ZJ Grand Cherokee Forum 7 11-15-2008 01:57 AM
2004 Grand Cherokee I-6 wont crank... 98zjdave ZJ Grand Cherokee Forum 1 10-22-2008 05:45 PM
96 grand cherokee crank, no start, wiring??? JE55E ZJ Grand Cherokee Forum 2 10-31-2005 06:50 AM
