2003 Grand Cherokee Window fuse... - JeepForum.com
post #1 of 8 Old 07-21-2008, 01:48 PM Thread Starter
CBlakeNS
Is there a window fuse and where is it located? I looked but I cant find it.. its the front and rear passenger windows that I need help with.
Thanks,
Blake
CBlakeNS is offline
post #2 of 8 Old 07-21-2008, 02:10 PM
cadencedad
cadencedad's Avatar
does it make a noise.Its usually the window regulator.Jeep is cheep on some parts
cadencedad is offline
post #3 of 8 Old 07-21-2008, 02:30 PM Thread Starter
CBlakeNS
I dont know I pulled the panel off so everything is unplugged......
Is there a fuse for the windows that I can check?
CBlakeNS is offline
post #4 of 8 Old 07-21-2008, 02:31 PM
tennesseewj
Slow down player. Did they just suddenly stop working one day or what?
I doubt you had two regulators go at exactly the same time, so if they both stopped working at the same time it could be the switch or the wiring harness also. Describe the problem so we're not sending you on a wild goose chase
Here is where the fuse is, though, so you can go ahead and check that
http://www.wjjeeps.com/misc/power_dist_ctr_02.jpg
2004 4.0 Selec-Trac
BB->Black Diamonds->General Grabbers
Originally Posted by Sporer65 View Post
You need to learn, there are 3 things that all JF members must like beside Jeeps:
(1) Guns (2) Women (3) Bacon
Originally Posted by GraKee99 View Post
I was bored so I forded the river. No oxen were lost.
tennesseewj is offline
post #5 of 8 Old 07-21-2008, 04:45 PM Thread Starter
CBlakeNS
I got the rear window working by just hooking the front door panel up again. However the front passenger side window does not work still...Whenever I press up or down on the switch, you can hear something moving inside but the window does not go up or down.
CBlakeNS is offline
post #6 of 8 Old 07-21-2008, 09:10 PM
tennesseewj
That sounds like a window regulator to me. It's not terribly expensive or difficult, but an inconvenience for sure. If you search the term you'll probably find some good places to buy one
2004 4.0 Selec-Trac
post #7 of 8 Old 07-21-2008, 09:23 PM Thread Starter
CBlakeNS
I can get a regulator and motor together in one piece for 65 dollars but I do not know really how to install it....The only reason I can get it for so cheap is because I know a bunch of people in parts business. I went to the dealership to me and they said they wanted like 435 bucks or something to do it, I told them they had to be out of there minds.
CBlakeNS is offline
post #8 of 8 Old 07-21-2008, 09:31 PM
tennesseewj
Yeah $65 is about what I paid when we had to fix one in my Mom's 03. It's an easy install, unbolt old, install new. If I remember right a Haynes manual has the steps in it with some pictures.
2004 4.0 Selec-Trac
2003 Grand Cherokee Overland matt21484 WJ Grand Cherokee Forum 21 06-25-2012 07:53 PM
2003 grand cherokee wipers sams ZJ Grand Cherokee Forum 4 01-08-2009 09:34 AM
Need Help w/ 2003 Grand Cherokee aga080 ZJ Grand Cherokee Forum 6 03-26-2008 12:35 PM
2003 Grand Cherokee Overland... jonsjeep WJ Grand Cherokee Forum 15 06-08-2004 12:59 PM
2003 Grand Cherokee BimmerMan WJ Grand Cherokee Forum 2 08-08-2003 06:07 AM
