2002 Grand Cherokee Cruise/Air Vent problem - JeepForum.com
post #1 of 2 Old 09-08-2008, 08:09 PM Thread Starter
lmronby
My internet research suggests this is a vacuum problem. I have seen it suggested on a few sites... i.e. Here
Also some jerk was nice enough to run a red light and bang up my front right corner 2 years ago. Repairs were made but I believe there is a vacuum box somewhere behind that front passenger fender. The problems are new but maybe the damage to that area caused something to work loose.
What do you pros think? Does anyone have a vacuum diagram so I can try to chase down a possible leak? Thanks in advance.
-Lmronby
lmronby is offline
post #2 of 2 Old 09-08-2008, 08:46 PM
JoshuaDHarp
Check the small rubber hose right underneath the battery tray (front side, I could see mine without pulling anything although if you need to fix it you will most likely have to pull the battery and the tray). There is a hose that runs to a nipple. I just fixed my wifes the other night with the same issues you are having.
If the hose does have a hole or is dryrotted you can try taping it up or cutting the end of the hose off and re inserting it on the nipple.
JoshuaDHarp is offline
04 Jeep Grand Cherokee Laredo Cruise Control problem stanj WJ Grand Cherokee Forum 47 01-21-2016 11:25 PM
95 Grand Cherokee AC vent problem markduffield ZJ Grand Cherokee Forum 1 05-02-2008 09:10 AM
1996 Grand Cherokee - Cruise Intermitten muzicman82 ZJ Grand Cherokee Forum 3 06-30-2007 11:50 AM
Grand Cher 2002 Cruise Control bg2095 ZJ Grand Cherokee Forum 1 05-16-2006 07:38 PM
gas tank vent on 96 grand cherokee sexyvic1 ZJ Grand Cherokee Forum 1 10-26-2005 02:35 PM
