2001 Grand Cherokee Limited rotor removal... - JeepForum.com
post #1 of 6 Old 10-11-2004, 06:54 PM Thread Starter
RickJeep
Hi,
I am currently trying to remove the front rotors from my 2001 Grand Cherokee Limited. I managed to get the caliper and caliper brackets removed, but can't seem to budge the rotors themselves. I can't see any clips holding it on anywhere. I have tried whacking it with a hammer, everything!!
What am I missing? Do I have to remove the centre hub nut???
Any help here would be greatly appreciated!!
Thanks
Rick
RickJeep is offline
post #2 of 6 Old 10-11-2004, 07:36 PM
driabyor
driabyor's Avatar
1994 ZJ
well i cant say for sure about yours but mine just slide off.... there may be a retainer on them.... may just need a little penetrating oil..... to loosen it
driabyor is offline
post #3 of 6 Old 10-11-2004, 07:58 PM
motohead84
rotor removal
I just did my front rotors. If you have the factory rotors on still, there are round retaining clips on the wheel studs that hold the rotor in place. You remove them by clipping them with a set of wire cutters.
On another note, I remember after I cut the retaining clips off, I had to hit the rotor really hard to get it to break free of the hub. I mean REALLY hard, I ended up breaking pieces off the old rotor off before it would break free. Jeep rotors have a history of going bad and becoming cracked and worn, which explains why the rotors come off in pieces.
Hope this Helps.
Andrew
motohead84 is offline
post #4 of 6 Old 10-12-2004, 12:33 AM
AnDaCo2002
I just did my front brakes and my rotors had the same problem. My dad, his friend, and I tried everything we could think of - hammers, spray, etc. We ended up getting a gear puller and with a couple turns of the wrench they popped right off. It did not harm them either and we were able to have them turned so that we could reuse them.
AnDaCo2002 is offline
post #5 of 6 Old 10-12-2004, 08:44 PM
toneytigger
rick get a 3lb hammer and hit the rotor in a star pattern and it will break free ( note)
dont hit it in the area where the pads ride hit it in the crown area just outside the studs and it will break free it semms with dirt heat and a small amount of time the rotors really get stuck on
toneytigger is offline
post #6 of 6 Old 07-14-2012, 08:45 PM
Blue83CJ7
1980 CJ7
My 2007 Grand Cherokee is actually SIGNIFICANTLY newer than this thread, but as I was about to give up this thread convinced me to go beat it harder.
You can't hit it in a star pattern as mentioned because of the dust shield but since new rotors are $50, and turning the old ones is $40 I just beat the crap out of mine where the dust shield is cutout and got new ones.
It dinged up the surface, but I am going to use the old rotors to make a semi-portable vice-stand for my garage since I don't really have a solid bench to mount it to.
1980 CJ7 - The Grenade
Blue83CJ7 is offline
Rear rotor removal on a 99 Grand Cherokee dirtyjeepdc ZJ Grand Cherokee Forum 5 05-08-2009 01:08 PM
Just bought a 2001 jeep grand cherokee limited mckyMOUSER ZJ Grand Cherokee Forum 0 05-15-2008 08:01 PM
2001 Grand Cherokee Limited mihighcherokee ZJ Grand Cherokee Forum 3 10-13-2005 12:51 PM
Cap and Rotor Removal for 95 Grand Cherokee... G4teamG ZJ Grand Cherokee Forum 12 06-27-2005 06:24 PM
HID options for a 2001 Grand Cherokee Limited?? sna77 ZJ Grand Cherokee Forum 16 03-12-2005 11:49 PM
