2001 Grand cherokee double cardon - Page 2 - JeepForum.com
post #16 of 19 Old 03-01-2010, 07:56 PM
skain8
skain8's Avatar
Make sure you get some direction on how to set up the multiple double cardan. Unfortunately, it's not as easy as slapping it in there and running any angle as you'd like. I'm sure the folks at Carolina can inform you about the install. At that height, you still should be able to get away with a standard double cardan, but I suppose results vary. Good luck, and report back the results.
'02 WJ: 4.7L, 5", HP44/9", 231HD, tall & skinny KM2's
skain8 is offline
post #17 of 19 Old 03-01-2010, 08:02 PM Thread Starter
shawnurich74
I just ordered it, cost 370 shipped. I have to change my yokes for it to fit.
shawnurich74 is offline
post #18 of 19 Old 03-09-2010, 06:11 PM Thread Starter
shawnurich74
So I got the driveshaft with new yolks. Can I just install the new yolks or do I need to switch the cup from the old yolk to the new one or will it seal itself?
post #19 of 19 Old 07-07-2013, 08:57 PM
fast803
whats the specs on the tires your running?? I want the exact same ones for mine after my iro 6.5' lift
fast803 is offline
2001 grand cherokee horn silverfly01 WJ Grand Cherokee Forum 5 12-09-2013 05:52 PM
Double Din Conversion for an 01 Grand Cherokee Limited keithhuggz ZJ Grand Cherokee Forum 17 03-21-2013 02:17 PM
How do I set timing on 2001 grand cherokee 4.0 jeepdudeuk ZJ Grand Cherokee Forum 8 10-20-2009 02:35 PM
Q about Ball joint inside Double Cardon craddock01 ZJ Grand Cherokee Forum 17 05-09-2009 04:23 PM
2001 Grand Cherokee 4.7 crazycardfan1 ZJ Grand Cherokee Forum 9 01-04-2009 10:41 AM
