2001 4.0 Piston In Pieces Help!!!!! - JeepForum.com
post #1 of 9 Old 09-22-2009, 03:14 PM Thread Starter
jeepdudeuk
Hi everyone, well turns out my lifter tap turned out to be a broken piston, after installing a new crank and lifters!!
Car is 2001 Grand 4.0 ltd done 102000 miles with full dealer history.
i have read a few threads on here and understand that the pistons in this year car were weak!!!
No 4 piston is in bits in the sump so will need to replace it, my question is where do I buy one or 6 pistons with rings from and the right price and is there a stronger version that I should install or have Jeep rectified the problem?
Me being from England struggle to get cheep parts or any helpfull info so some help would be great.
I have had a look on globaljeepparts.com is this the right place to help???
Thanks
1 Love
jeepdudeuk is offline
post #2 of 9 Old 09-22-2009, 04:17 PM
StrokedWJ
StrokedWJ's Avatar
I'll recommend Falcon automotive parts 800-756-1114. They're in Florida and I don't know about international shipping but thats where I got my parts from when the same thing happened to me. They have awesome prices and great customer service.
2000 WJ 4.5L - Stroked, Locked, & Long-Armed
Looking for 6" WJ springs!
StrokedWJ is offline
post #3 of 9 Old 09-22-2009, 09:37 PM
Brian's 97 ZJ
Brian's 97 ZJ's Avatar
If your piston failure was anything like mine, you're going to want to pull the head off and check for damage to the cylinder walls. It may not be as simple as just replacing the piston.
The wrist pin scored the walls pretty deeply. Mine was the #3 that failed. Drove it around 6 miles like that to get it home.
Good luck and keep us posted.
- Brian
For some reason, being a member of the
just isn't as cool... Member #1
Brian's 97 ZJ is offline
post #4 of 9 Old 09-22-2009, 10:01 PM
WiCkeDuDe
Dude a little engine restore poured in will take care of that in no time. Restore your horsepower.
- Brian
I Have WJ Stuff for Sale
WiCkeDuDe is offline
post #5 of 9 Old 09-23-2009, 12:48 AM
driabyor
driabyor's Avatar
1994 ZJ
Is the block ok....
Flatlander Racing - AMC & Jeep Engine Rebuild Kits
Master Engine Kits $ 609
Include:Pistons, Rings, Gaskets, Cam Bearings, Rod Bearings, Main Bearings, Oil Pump, Freeze Plugs, Camshaft, Lifters, Pre-lube, and Timing Set, and Valley Pan (if applicable)
.Overhaul Kits$355
Include: Pistons, Rings, Gaskets, Cam Bearings, Rod Bearings, Main Bearings, Thrust Washers, Aux Shaft Bearings (if applicable), and Valley Pan (if applicable).
Re-Ring Kits$229
Include: Rod Bearings, Main Bearings, Thrust Washers, Rings, Gaskets, Valley Pan (if
AMC-Jeep 242 4.0 L6 ('99-02)
Note: w/HYPER Pistons51008D $229 $355 $609
94 Grand Cherokee ... 332,000 miles
5.2 liter 242 :)
Rancho 5000 steering stabilizer
driabyor is offline
post #6 of 9 Old 09-23-2009, 01:07 AM
ratmonkey
R.I.P.
ratmonkey's Avatar
If you drove for much time on a cracked piston you're probably in need of some machine work on the block. Or a new block.
Good luck.
ratmonkey is offline
post #7 of 9 Old 09-23-2009, 03:39 AM Thread Starter
jeepdudeuk
piston will be out tonight so will keep you all posted on the block!, can anyone tell me where to get the piston???
1 Love
post #8 of 9 Old 09-23-2009, 10:10 AM
LordHobbit
rockauto, summit, autozone, any other local part store, you name it you can probably get one.
93 red ZJ 190k 4.0. Spent more money than I should have ...
Isn't red the only color a vehicle should be?
If at first you don't succeed, use more speed.
LordHobbit is offline
post #9 of 9 Old 09-23-2009, 03:05 PM
StrokedWJ
StrokedWJ's Avatar
I dunno if you missed my post recommending Falcon...but their prices are the best you'll find. When I called around the local auto parts stores (NAPA, Autozone, etc) the pistons were ~ $45 each. I got the same piston (Speed Pro) for ~ $16 from Falcon. And for whats its worth, I'd REALLY recommend replacing all of them while you're in there. You'd hate to have this happen again.
Transmission pieces in oil pan Tony ZJ Grand Cherokee Forum 15 09-09-2009 03:00 PM
4.7 HO piston slap JForest2 ZJ Grand Cherokee Forum 5 08-17-2009 11:29 AM
IRO 2" BB All The Same Pieces? RrCoX22 ZJ Grand Cherokee Forum 13 04-11-2009 11:32 PM
2001 GC 4.7 Limited vs 2001 Dodge Ram 1500 Quad Cab Jdb107 ZJ Grand Cherokee Forum 0 03-23-2008 08:13 PM
Piston size? 95 v. 97 Vestjam ZJ Grand Cherokee Forum 0 12-18-2006 04:46 PM
