2000 WJ limited: spun a pinion bearing! Rebuild axle or replace it? - JeepForum.com
post #1 of 3 Old 01-09-2010, 07:03 PM Thread Starter
kkady
I believe I spun the rear pinion bearing in my front axle. Its in a 2000 WJ limited with the quasi-track II. Whats involved in a rebuild? Do I need special tools? How do I confirm by properly troubleshooting? Where can I go for guidance in doing the job? I have a shop manual, but its calling for special tools. Best place to purchase parts for it? Much thanks for any input!
kkady is offline
post #2 of 3 Old 01-09-2010, 11:24 PM
lakailimited06
replacing the bearing is a pretty good task...i've never done it but im pretty sure you're gonna have to remove the inner parts of the axle ( gears, carrier etc) to get access to the pinion gear/bearing...im not sure whats involved beyond that if you're gonna have to reset your gear pattern or what...
hopefully others will chime in good luck
99WJ 4.0
IRO 3", SYE, D30 aussie/8.8 aussie, 4.10s, 33's, skids/bumpers
lakailimited06 is offline
post #3 of 3 Old 01-09-2010, 11:37 PM
xJoshxx
2012 WK
you have to remove the hubs/axle shafts so you can pull the carrier
Sold4" Hybrid lift TeraFlex coils IRO Adjustable LA's Jks tracbar 1.25spidertrax spacers 265/75/16 Dura-tracs
Originally Posted by moPowered View Post
The SRt-8's are a liberty design.
2011 WK2 ORA2 sold
2012 WK2 SRT8 - Current
99 WJ Limited Lifted.
2001 WJ stock 4.0 304k miles
xJoshxx is offline
Replace Pinion Bearing without taking Diff Apart!!! ntaousakis ZJ Grand Cherokee Forum 17 05-20-2012 11:24 AM
2000 WJ axle identification and pinion bearing replacement kkady ZJ Grand Cherokee Forum 6 01-24-2010 03:45 PM
Pinion Bearing Rebuild Kit 97DCZJ ZJ Grand Cherokee Forum 32 12-10-2009 08:46 PM
hours to replace pinion bearing cmonson ZJ Grand Cherokee Forum 0 06-15-2008 05:23 PM
Front axle bearing replace wahoo50 ZJ Grand Cherokee Forum 1 03-19-2007 08:41 PM
