2000 WJ axle identification and pinion bearing replacement - JeepForum.com
post #1 of 7 Old 01-24-2010, 09:45 AM Thread Starter
kkady
I have a 2000 Grand Cherokee limited with Quadratrac drivetrain. I spun a pinion bearing in the front axle and need some advice.
First, which axle do I have? I have a shop manual, but do not know which axle is in the quadritrac. Which axle do I read up on to do this repair?
Do I need special tools to do this repair? Whats involved in it? Can anyone direct me to a link which explains this repair in laymans terms? the manual gets to be a bit confusing at times....
What can I expect to pay if I send out to get repaired? If I need special tools or if there are some critical steps involved, I may just send it out to someone who is familiar with it.
Much thanks for the input!!
Kevin
kkady is offline
post #2 of 7 Old 01-24-2010, 09:58 AM
StrokedWJ
StrokedWJ's Avatar
The only front axle available in WJ's is the low pinion dana 30. What do you mean you spun a pinion bearing? The pinion bearing is supposed to spin, thats what its job is.
2000 WJ 4.5L - Stroked, Locked, & Long-Armed
Looking for 6" WJ springs!
StrokedWJ is offline
post #3 of 7 Old 01-24-2010, 09:59 AM
xjfever
xjfever's Avatar
1995 XJ Cherokee
You should have a d30 up front. Replacing pinion bearings is pretty involved and things have to be set to correct tolerances. I would imagine the repair would cost from 300 to 400 dollars.
xjfever is offline
post #4 of 7 Old 01-24-2010, 10:18 AM Thread Starter
kkady
I don't know, what do you say when a bearing is shot? My pinion bearing was whining for months up front. Now it makes some ugly grinding and clicking sounds. Painful to drive! its been parked for a week now I refuse to use it. Money is tight and cannot afford much. I've been trying to research repair steps specific for this rebuild but need to I.D. the axle first. Anybody have a link which explains the steps? Also, where can I pick up the parts at reasonable cost? Much thanks,
kkady is offline
post #5 of 7 Old 01-24-2010, 10:28 AM
QuadraTokn
QuadraTokn's Avatar
1930 WJ
You need almost $1000 worth of tools to do it just right. And the pinion bearing HAS to be done just right.
NEW Dana 44a Axle Truss and Skid !
WJ Grand Cherokee Tube Doors For Sale !
ZJ Grand Cherokee Tube Doors For Sale !
PARTS FOR SALE from 10 WJ Grand Cherokees ! !
QuadraTokn is offline
post #6 of 7 Old 01-24-2010, 10:44 AM
StrokedWJ
StrokedWJ's Avatar
I'm not trying to be an ***, but you said you have a shop manual. The steps are in there.
post #7 of 7 Old 01-24-2010, 02:45 PM
QuadraTokn
QuadraTokn's Avatar
1930 WJ
but need to I.D. the axle first.,
see post #2 dude. LP D30.
A vendor on this forum, CCOR, has truly unbeatable prices for Yukon parts. Your parts will drop ship from Randy's R&P, but at a fraction of the cost.
2000 WJ Axle Bearing / Seal replacement help needed! jondilly1974 ZJ Grand Cherokee Forum 8 11-25-2010 02:47 PM
2000 WJ limited: spun a pinion bearing! Rebuild axle or replace it? kkady ZJ Grand Cherokee Forum 2 01-09-2010 10:37 PM
Dana 30 pinion bearing replacement. ZeJokee ZJ Grand Cherokee Forum 5 04-21-2009 08:56 AM
D35 Pinion Bearing Replacement... JrMechanic ZJ Grand Cherokee Forum 3 04-06-2009 06:33 AM
Pinion bearing replacement jmaley ZJ Grand Cherokee Forum 0 01-07-2006 01:17 PM
