2000 Limited Starting problem - JeepForum.com
post #1 of 5 Old 06-18-2008, 07:07 AM Thread Starter
bbhockey19
2009 JK Wrangler
So I go and start my WJ Limited to leave for work and I put the Key in the Iginition and try to turn it to start like normally but the Ignition wont turn at all so i try jerking the wheel maybe it is locked and etc.. but nothing happend after like 10mins of trying to turn the ignition the ignition moves finally and car starts.. This happend 2 days ago but never before in the life of the car.. What could be the problem?
2009 Black JK Unlimited Sahara 6pd, Hardtop, NAVI
AEM BRUTE FORCE INTAKE
MBRP Cat-back Exhuast
Mopar= Sills,Slush Mats, Splash Guards
Rugged Ridge Rear Grab handles
IPF 920H4 headlights
bbhockey19 is offline
post #2 of 5 Old 06-18-2008, 10:01 AM
tbm5690
So you're saying that the ignition would physically not budge? I'm assuming you had it in P, because what you're describing occurs when the vehicle is in gear and you try to start it (maybe it slipped out of gear?) I'm not sure how the sentry key immobilizer system works, but maybe the CPU wasn't picking up the chip in the key?
2001 Grand Cherokee Laredo S/A package 4.7L V8
K&N high-flow filter, Airaid MIT, Flowmaster 50 catback
tbm5690 is offline
post #3 of 5 Old 06-18-2008, 11:20 AM Thread Starter
bbhockey19
2009 JK Wrangler
yes the vechile was in park... i even tried my spare key and it did the same thing until finally i tried turning it and it finally turned otherwise you couldn't move the key left or right while it was in the ignition
post #4 of 5 Old 06-18-2008, 03:00 PM
tbm5690
Sounds like a mechanical problem in the ignition then...if it happens again take it to a local shop and see what they think.
tbm5690 is offline
post #5 of 5 Old 06-20-2008, 09:41 PM
mailforjon
mailforjon's Avatar
2005 WK
bad ignition cylinder (tumbler). need to replace then have it keyed to your current key.
-2005 WK 5.7 Limited [DD]
-1999 WJ 4.7 Limited [SOLD]
-1998 ZJ 5.9 Limited [SOLD]
-1996 ZJ 5.2 Laredo [SOLD]
-1994 ZJ 4.0 Laredo [SOLD]
-1993 XJ 2.5 [SOLD]
mailforjon is offline
01 Jeep GC Limited WJ Starting Problem DJHile WJ Grand Cherokee Forum 15 12-14-2013 09:14 PM
2000 WJ Limited Pin Stripe Problem HeliDoc ZJ Grand Cherokee Forum 3 03-23-2009 06:29 PM
2000 GC starting problem SWDoodle ZJ Grand Cherokee Forum 2 01-24-2007 05:45 PM
2000 WJ Problem Starting ivanfuzz ZJ Grand Cherokee Forum 21 05-07-2006 07:14 PM
2000 limited problem kcorbs WJ Grand Cherokee Forum 3 06-23-2003 04:51 AM
