2000 grand cherokee limited ac wont switch over - JeepForum.com
post #1 of 4 Old 07-31-2008, 06:49 PM Thread Starter
shawna0888
2000 FSJ Cherokee
i have 2000 grand cherokee limited and am having issues with the ac. it has the dual ac(dont know if all come that way or not) well sometimes the ac wont blow out the top vents, it will either come on through the floor board or the the windshield defroster, and sometimes it will blow out hot air through the passanger side (floor board or top vents). i have looked all around the internet to try to find the issue and i cant find it. i think its just the console and switches that are messed up. because it was 100+ degrees outside and i was so irritated that the ac wouldnt work properly that i gave it an opened hand hit right on the console and it switched over and started working. anyone have this issue? i want to fix it/have it fixed! all help would be appreciated.
shawna0888 is offline
post #2 of 4 Old 07-31-2008, 06:52 PM
gatorayde
search, "blend doors"
To summarize it before you search though, the doors inside the air ducts that limit/allow flow of hot/cold air, have broken and are allowing hot/cold air through that shouldn't. It's not fun to fix, nor is it cheap so have fun
gatorayde is offline
post #3 of 4 Old 07-31-2008, 08:34 PM Thread Starter
shawna0888
2000 FSJ Cherokee
I believe it is the dual climate control console piece itself, because the lights will be dim, so lets say. i put the temperature to low for the driver and the passenger...well when i turn on the ac the lights that say "LO" wont be lit up very bright, and it will blow hot air from the floorboard, so when i hit the screen that says "lo" it will then light up and start blowing cold air out of the vents. My question is where can i find the whole console piece, im not sure what it would be called.
post #4 of 4 Old 06-27-2013, 12:14 PM
naotyl04
Hello Shawna0888, did you have the issue resolved? I am having the same issue and seeking for solution. thanks
naotyl04 is offline
2000 grand cherokee wont start wrenb06 ZJ Grand Cherokee Forum 0 01-24-2010 01:40 PM
2000 Grand Cherokee Limited 4,7 immo problem lundve ZJ Grand Cherokee Forum 5 12-28-2009 02:52 PM
2000 Grand Cherokee Limited 4WD - Service Question worldly ZJ Grand Cherokee Forum 2 07-17-2006 10:22 PM
No Heat on a 2000 Grand Cherokee Limited mlee1steph ZJ Grand Cherokee Forum 1 11-17-2005 03:06 PM
2000 Grand Cherokee Limited wipers size ??? Webb WJ Grand Cherokee Forum 3 11-17-2003 11:11 AM
