2000 gc runs at 210 - JeepForum.com
post #1 of 7 Old 07-19-2009, 08:18 PM Thread Starter
rojoswan
2000 gc runs at 210
I just replaced a cracked head on my 2000 4.0 gc. the waterpump and thermostat are both new, The engine runs at 210 degrees. What can I try to cool it down.
rojoswan is offline
post #2 of 7 Old 07-19-2009, 08:34 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
that's the proper operating temperature for a jeep.
stock thermostat is 195 and it generally runs about 205-210. that's the temp the pcm wants to see to run at peak efficiency.
ratmonkey is offline
post #3 of 7 Old 07-19-2009, 09:09 PM
the88thpianoman
2003 WJ
Agreed... 210 is a sign your 4.0 is in great shape.
Also... another victim of the cracking of the early 0331 head casting.
2003 WJ in Jeep Green Metallic, 4.0/242/4.10's. 4" Teraflex springs w/ RE monotube shocks and IRO short arms, cheap intake w/ amsoil filter, 2.5" hi flow cat and back exhaust, lots of lights and other misc crap.
Check out my build thread here:
the88thpianoman is offline
post #4 of 7 Old 07-19-2009, 09:30 PM Thread Starter
rojoswan
Thanks, I was concerned that something was haywire, Also I just checked the electric fan and it seems to be working only when jumped, do you suspect the relay and if so where is it located
rojoswan is offline
post #5 of 7 Old 07-19-2009, 09:39 PM
the88thpianoman
2003 WJ
Fan control relay is a common failure. It is located under the passenger headlight. It's not hard as long as you have a dremmel tool or something similar. Someone can probably link to a write up.
post #6 of 7 Old 07-19-2009, 10:46 PM
xJoshxx
2012 WK
Hey Pianoman you got a picture of where the BLOCK casting is please Im leaking pretty much on 6-2 on my head and im worried im leaking the most around 5,6 tho.
Sold4" Hybrid lift TeraFlex coils IRO Adjustable LA's Jks tracbar 1.25spidertrax spacers 265/75/16 Dura-tracs
Originally Posted by moPowered View Post
The SRt-8's are a liberty design.
2011 WK2 ORA2 sold
2012 WK2 SRT8 - Current
99 WJ Limited Lifted.
2001 WJ stock 4.0 304k miles
xJoshxx is offline
post #7 of 7 Old 07-20-2009, 12:19 AM
4jeepers
Thats how they run! Mine runs anywhere from 208-210!
4jeepers is offline
5.2 v8 runs but not well enough to drive psykomike ZJ Grand Cherokee Forum 4 12-05-2009 11:12 PM
99 4.0 hardly runs B_palmer22 ZJ Grand Cherokee Forum 3 09-30-2008 11:14 PM
Who all runs OME suspension in there zj? platinum5.9 ZJ Grand Cherokee Forum 8 02-14-2007 08:32 PM
A/C still runs after key taken out fedup1 ZJ Grand Cherokee Forum 13 08-21-2006 02:21 PM
2000 Gc 4.7l Runs Hot Towing!! mpdiecast ZJ Grand Cherokee Forum 14 06-16-2005 05:01 PM
