#1 | |
2000 GC getting P 203 code
does any one know what this means and how to fix it . I was told it might be some kind of seloniod somewhere. any help would be great. when the light comes on it also effects the way it shifts and the rpms go up while driving.
#2 |
Code P0203 means an open or shorted condition detected in control circuit for Injector # 3 or the INJ 3 injector bank. I recommend going to wjjeeps.com, lot's of useful information. My guess would be your number 3 fuel injector is on its way out. Try switching the injector with another injector and see if it gives you a different code if so then you foudn your problem.
[B][COLOR=Navy]00 WJ I6 4.0L 4x4, FIPK Gen2,Borla Exhaust Magnaflow tip, Carsound Cat, 62mm TB,Alarm/Remote start,Tinted windows,Front and rear tow hooks,Hypertech programmer3. Addco rear and front sway bar, Hid's 8500k[/COLOR][/B] [URL]http://www.cardomain.com/id/othoni[/URL] |
#3 |
I have all 8 of those codes, I can't believe all 8 are out though.
#4 |
ok thanks... i went to check the code again and this time left it on and more codes came up. This is what i got now.... p0203,204,205,206,207,208,202,201 and p0121.
#5 |
No I think the ignition system is fine. I believe the injector codes are a result of something else … like the throttle position sensor or the MAP sensor. Start with the TPS.
Cheers Steve Trained Professional Crack-pot Go RU & WVU Football Teams 94 Black Laredo 4-Liter with QuadraTrac (42RE trans & NP249 TC) 200,000 + miles purchased new 03 4Runner V8 (my wife's car) 94 Volvo 850 (my 16-yr old daughter's car) Five cylinder 88 Cherokee 2-door with 5speed manual 139K miles(deceased) purchased new |
#6 |
ok thanks.... i just had the tbps replaced and the codes were erased. I guess i will see if that fixes the problem. ... thanks again!!!
#7 | |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
