Quantcast 2000 4.7 engine code help - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > 2000 4.7 engine code help
Old 05-03-2006, 11:44 AM   #1
chipflyer
Hi everyone,
I have a 2000 Grand Cherokee with a 4.7 engine with 70,000 miles and it now runs a little rough. It might run good one day and then terrible the next, the main symptoms are poor idle, heitatation and bucking. I have pulled the codes and they are as follows.
0202
0204
0206
0207
Anybody else ever see the same thing? All codes seems to be tied to the injector control circuit but what does that mean? Is there a quick fix?
Any info would be appreciated,
Thanks
Jeff
chipflyer is offline   Reply With Quote
Old 05-03-2006, 06:48 PM   #2
10achik
I ate what?
10achik's Avatar
Here you go:
http://www.wjjeeps.com/faultcodes.htm#DTC
P0202 (M)
Injector # 2 Control Circuit
An open or shorted condition detected in control circuit for Injector # 2 or the INJ 2 injector bank.
P0204 (M)
Injector # 4 Control Circuit
Injector # 4 or INJ 4 injector bank output driver stage does not respond properly to the control signal.
P0206 (M)
Injector # 6 Control Circuit
Injector # 6 output driver stage does not respond properly to the control signal.
P0207 (M)
Injector # 7 Control Circuit
Injector # 7 output driver stage does not respond properly to the control signal.
Sounds like a trip to the stealership to me...Sounds like your injectors aren't getting a cood signal to tell them what to do. Never experienced this problem myself, hopefully someone can give you some idea. Good Luck.
Ken
99 GC Limited - 4.7L HO V8, 6.5" IRO HC LA lift, F&R D44s locked & trussed, 242HD, IRO TC Skid, KMA Bumper, 33" Yokohama Mud Rovers
2006 Saturn Redline -2.0L Eaton supercharged I4, GMPP Stage 2, Custom Tune, AEM CAI, Falken 912's (13.76 @ 103.85)
2006 Pontiac G6 GTP - (her's)
2001 Dodge Ram 1500 - CAI, Soft 8's, 31's
2000 SV650 - naked, integrated tail light, sliders, corbin, pilot roads, RK chain & sprokets, D&D full exhaust, FactoryPro Stage I jet kit, +4 Ignition Advancer, Barnett race clutch
2006 Triumph America 900 - Full Dresser
January 2009 Grand Cherokee of the Month (GCOTM)
10achik is offline   Reply With Quote
Old 05-04-2006, 11:00 AM   #3
chipflyer
Thanks for the reply Ken, anybody else got an idea?
Jeff
Old 05-04-2006, 12:03 PM   #4
rm2001wj
Confirmed Street Jeeper
rm2001wj's Avatar
If anyone has been working under the hood lately, I would suspect some injector connectors/wires got messed up.
Otherwise, I would suspect that the crankshaft position sensor (a.k.a. CPS or CKP sensor) is going bad. If it fails completely, the engine won't start. If its operation is erratic, then it causes problems like you see. The sensor is not expensive and replacement is a DIY job.
Another candidate is the camshaft position sensor (a.k.a. CMP sensor). Its operation is much like that of the CKP sensor and can operate erratically without complete failure or throwing a code. This sensor is not expensive and replacement is a DIY job a little more difficult than the CKP.
The most expensive candidate would be trouble with the PCM which would require its replacement.
Maybe other responders will have some additional ideas.
2001 WJ Limited with Quadra-Drive, Kenne Bell Supercharger, 3-inch Kolak exhaust, Stillen rotors (F/R) and MM pads, Addco sway bars (F/R).
rm2001wj is offline   Reply With Quote
Old 05-04-2006, 06:51 PM   #5
chipflyer
It has on ocasion cranked a little longer than it should. It hasn't done that lately but it did start that before these other issues stated. That thing always did turn over and start quickly so I did notice when I had the extended crank time. The last 2 days the chk eng lite is out and it runs great, so it is intermitent. I had a 92 with a 4.0 that had the CKP completely quit so I have experienced the joy of replacing that one. I think I may try the CKP sensor. Is aftermarket OK or would you go OEM?
thanks
Jeff
Old 05-04-2006, 08:05 PM   #6
rm2001wj
rm2001wj's Avatar
I favor Mopar (OEM) sensors. Aftermarket will usually work, at least for a while, but some give trouble in the long run.
Glock Forum
