01-06-2008, 09:05 PM
#16
Originally Posted by driabyor
wd 40 is a better substitute for ether.
if you haven't already ,put more fuel in the tank.
the pump slide up and down a few inches so it will remain in contact with the bottom of the tank. it may be stuck at the top. A 1" or 2" from the bottom. the plastic tank expands and contracts.
Thus not sucking fuel... Bad filter.. It's underneath above the left tire area.
wow i thought 230k was alot of miles lol... you got me beat!
94 XJ 4.5" D30 aussie/8.25 welded 4:10's 33's
94 ZJ 5.2 3" 31's
[url]www.undergroundjeeps.net[/url]
01-06-2008, 09:06 PM
#17
the jeep will still run even with a dirty filter since there is the sock on the pickup, the pressure will still force enough gas through to run but it just wont run as good
big lift, sick tires, awsome accessories, alot of custom work.
my jeep won the war, your honda mows my lawn
01-06-2008, 09:42 PM
#18
Look for some fuel pressure... I don't know where the Schrader Valve is on a 5.2 Liter. On the 4.0 it's super easy to find Front & Center. Short answer is if you turn it to run (No Cranking it) for 30 seconds then unscrew the cap and push down the dimple of the schrader valve it should give you a little burp of fuel. IF it does then you can eliminate a whole bunch of issues. If you get nothing then it could be a bad pump or at least a bad fuse. Typically bad filters will cause insufficient flow and make if cough and wheeze at freeway speeds. Also Throw on a new coil... If it is "ALMOST" dead some starting fluid will miss lead you in to thinkging it's not an ignition issue.
I'm not a mechanic put I play one on the internet...
I Want $200 Jeep too! I'm about to spend 7 X that on new tires for both of my WJ & WK
One does not establish a dictatorship in order to safeguard a revolution; one makes a revolution in order to establish a dictatorship. - Orwell
01-07-2008, 06:59 AM
#19
The pump does not move once installed. The pump housing is spring loaded. When installing the pump it gets compressed from its original extended length. This is so it is constantly forced onto the bottom of the tank and also so that it can be used with different gas tank designs (like Dodge gas tanks)
Cheers Steve
Trained Professional Crack-pot
Go RU & WVU Football Teams
94 Black Laredo 4-Liter with QuadraTrac (42RE trans & NP249 TC) 200,000 + miles purchased new
03 4Runner V8 (my wife's car)
94 Volvo 850 (my 16-yr old daughter's car) Five cylinder
88 Cherokee 2-door with 5speed manual 139K miles(deceased) purchased new
01-07-2008, 10:33 AM
#20
Originally Posted by greasefingers
Just a note: many people get this confused. Spraying starting fluid (like Ether in the old days) is so volatile that it spontaneously combusts due to the pressure and temp in the cylinder. This is not a test to see if the fuel system works. It just means that one can start the engine with Starting Fluid.
 It's been so long since I learned that lesson I forgot it. Took me about 3 weeks to come up with that info when I was about 16 years old. My foot was sore from kicking my ol 71 chev truck.
I bought "MY JEEP" for my wife
I bought "MY OTHER JEEP" for my daughter [she sold it]
I finally bought one for me
Canadian Jeep Club Member #7
99 GC limited
4.7 Quadradrive
97 TJ Sport
4.0 5 speed
99TJ Sahara
4.0 Auto
Sold to a life of blacktop
94 ZJ Limited
I6 Quadratrac
01-09-2008, 07:49 AM
#21
alright i have the day off from work so when it stops raining i'l start trouble shooting
94 ZJ 5.2 3" 31's
01-09-2008, 09:54 AM
#22
isnt it dangerous to spray starting fluid into the intake like that to get it to start and keep it running???
1995 JGC Limited 5.2 v8, black with gold trim
1976 Olds 98, 82 Olds 98, 84 Olds 98, 89 Trans AM
[url]http://s221.photobucket.com/albums/dd197/alivenkickin28/[/url]
01-09-2008, 10:36 AM
#23
maybe I missed the point here..
you paid $200 for a non-running Jeep.
what's the issue?
oh!!.. you expected it to run for $200 !!!!? HAHAHA.. sigh, that's a funny one.
i paid $6000 for mine and it doesn't run, so I don't see why yours should run for $200
where is the thread on worst stuck Jeep Compass?
01-09-2008, 12:59 PM
#24
what's the issue?
 hahaha so true...I am pretty sure a lot of us can relate there.
-Pat
I am now a dealer for Iron Rock Off Road
I offer the same great products you already know about,
the same low prices you have been seeing, and with
the same experienced customer support, but I can offer it nearly 24/7
"Project Dirty Princess"
5.9 ZJ 7" IRO, 35s, 8.8, hp30, locked, blah blah
"Project Grow A Set"
Originally Posted by CMARJEEP
Those tires look freakin awesome Redhat... took the ZJ up a notch in my book. Now you're at notch 2.
01-10-2008, 09:13 AM
#25
what's the issue?
Laugh all you want but i DO have a $200 RUNNING ZJ... and it cost nothing to get it running.. all we did was reset the alarm
It runs great! tho we did find the reason to it originally being at the junkyard... front axle is toast... pinion flops all over the place. no problem, i wanted to swap a HP D30 in there anyways
94 ZJ 5.2 3" 31's
01-10-2008, 11:02 AM
#26
You know the rules... We want Pictures or it doesn't exist!
01-10-2008, 08:38 PM
#27
here ya go..
http://viewmorepics.myspace.com/inde...lbumId=1567238
94 ZJ 5.2 3" 31's
01-15-2008, 05:49 AM
#28
Well thanks to me + Google she is up and running. $200 and triple A got him a good running V8 ZJ. Front axle deffinetly is toast. Just gotta find some nice heavy duty replacement rockers.
Also....Alan...STOP UDING MYSPACE TO HOST ALL YOUR PICS!!!! lol Use picpile.net to post pics up on here.
4.2 EFI - Pacesetter header - Flowmaster - 4.5" RE XD - RE Monotubes - 35" Trxus M/Ts - 4.10s - D30 Aussie - 8.8 Trac Lok - NV3550 - Centerforce Dual Friction - B&M Shifter - ARB Snorkel - Livewires - M8000 - Duralined interior - custon front bumper - custom brush cables - HiLift on the hood with lights
"Don't follow me, You won't make it!"
01-15-2008, 06:39 AM
#29
great find! no myspace pain in the backside!
01-15-2008, 09:43 AM
#30
haha, i never post pics and when i do i've been too lazy to use picpile.net lol
94 ZJ 5.2 3" 31's
