2 speed fan with PWM controller - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > 2 speed fan with PWM controller
ROCK BOTTOM prices on LIFT KITS at Rockridge4wd!! WANT TO Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineJeep Grand Cherokee Tie Rods & Adjusting Sleeves
Unread 03-10-2015, 12:00 PM   #1
Nexx2015
Hi, I was walking around sunday a new local JY and came across a 1996 Lincoln Mark VIII with the fan still in it so I pulled it out & tested it, and it came home with me for $23. I did look for the Volvo relays with no luck. now looking for a controller. I read about dccontrol.com but what i hear is the have long wait times and poor customer service. So my question is can I run this fan with a PWM controller on the high speed only and leave the low unplugged, Any possible damage to the high speed? Think about using this PWM controller Derale Fan controller. Thanks.
Nexx2015 is offline   Reply With Quote Quick reply to this message
Unread 03-10-2015, 03:44 PM   #2
kg6mov
Hears the voices
kg6mov's Avatar
It shouldn't damage it. I'd go the simple route myself.
If you do get that controller I would get one with a temp sensor that actually touches coolant, not the spike into the radiator probe.
1996 ZJ Green Laredo V8, 2.5" OME and Bilsteins, 31's, Holes drilled in the roof.
1998 ZJ Platinum Limited 5.9, New engine and trans, no front driveshaft, but it's pretty
"Whats wrong with a PT Cruiser?"
"Coulda had a V8!"
96 build thread
Niner build thread
kg6mov is online now   Reply With Quote Quick reply to this message
