2" spacer lift - Page 2 - JeepForum.com
post #16 of 21 Old 05-12-2009, 11:07 AM
ZooTech
Here's mine with a 2.25" budget boost and 31x10.5x15" tires (about as big as you can go on 2" without major rubbage):
~ 1995 ZJ
~ np242
~ 2.25" BB
~ Rough Country Nitro 9000 shocks
~ 31x10.5x15 Dunlop Radial Mud Rovers
~ 15x8 black Unique wheels
ZooTech is offline
post #17 of 21 Old 05-30-2009, 07:27 AM Thread Starter
guitarZERO
I doing this lift this weekend have some conflicting info on the spacers...should from top to bottom spacer, rubber stock spring cushion, spring. Or should the first two be swapped and I assume the flat side of the puck goes toward the spring<---that last one one just a really dumb question I had to ask.
if any one has a pic of the spring installed with the spacer that would be great too...
Thanks
-"If you are afraid to "fly" then don't expect to go very far..."
-"Your mistakes do not define you, they tell you who you are not..."
-"Mercy is for the strong."
guitarZERO is offline
post #18 of 21 Old 06-02-2009, 10:49 PM Thread Starter
guitarZERO
Ok BB lift is done...sweet! It is noticeably lower in the front than the rear. Any ideas on how to level it out?
post #19 of 21 Old 06-02-2009, 10:56 PM
Tiggerrrrr
How much difference is there? upcountry springs will lift the front an inch or removing the rear coil isolators will drop it 1/2-3/4".
'95 ZJ Limited 4.0
2.25" BB , 31 10.5 15 Treadwright MTG's on Black Rock steelies
Everything "pimpin' Gold" REMOVED!
Looking for a REAR tow hook and bracket!
Tiggerrrrr is offline
post #20 of 21 Old 06-02-2009, 10:57 PM
WhiteOut
WhiteOut's Avatar
You cant, short of adding more height
WhiteOut is offline
post #21 of 21 Old 06-03-2009, 06:07 AM Thread Starter
guitarZERO
what about a shock swap up front?
Question reg. 2"-3" spacer lift the squirrel ZJ Grand Cherokee Forum 7 05-09-2009 01:14 AM
Calling WJs with 4" lift, a-arm spacer and 32s doublejz ZJ Grand Cherokee Forum 1 04-11-2009 08:14 PM
2"-2.5" Coil Spacer lift Jammer73 ZJ Grand Cherokee Forum 2 11-02-2008 08:56 PM
2" Spacer lift with 265/70 R17 - Go or no Go? Polaris Junkie ZJ Grand Cherokee Forum 15 08-30-2006 09:36 AM
3" lift, 285-75-16 stock limited rims, and 1"wheel spacer. Will it work? bjl95mustang ZJ Grand Cherokee Forum 1 01-26-2006 11:17 AM
