2 questions I haven't seen for D35-D44a swap. - JeepForum.com
post #1 of 7 Old 04-17-2013, 12:22 PM Thread Starter
SCZJ
1994 ZJ
I'm doing the old D35-D44a swap as the 35 has had it and I have the 44a sitting here. I've researched but haven't seen two questions answered:
1) I'm going from drum brakes on the 35 to discs on the 44a. Will I have to change any brake lines or the master cylinder for the change in brake pressure due to the calipers?
2) Will any sensors or the speedo be affected?
Thanks for any input.
'94 ZJ, 4.0, D30/D44A, 4 1/2" lift, 32" tires, 3.73 gears, etc... Just another cookie cutter ZJ.
SCZJ is offline
post #2 of 7 Old 04-17-2013, 12:43 PM
Bigdjs123
I'm probably going to do this swap too. The speedo will not be affected unless you are changing gear ratio or tire size.
Bigdjs123 is offline
post #3 of 7 Old 04-17-2013, 05:44 PM
95zjman86
speedo will be fine unless gear ratio change. As for the proportioning valve I am not sure but I bet it has to be changed.
95 zj iron rock offroad 7 inch long arm front 242 swap 4.56 gears ford 8.8 with yukon grizzly bfg km2's 35 inch warn m8000
95zjman86 is offline
post #4 of 7 Old 04-17-2013, 05:46 PM
kg6mov
Hears the voices
kg6mov's Avatar
Speedo sensor is in the t-case on a zj so it shouldn't matter.
I don't know about the brakes.
kg6mov is offline
post #5 of 7 Old 04-17-2013, 06:16 PM
dnuccio
doesn't matter where the speed sensor is, it would still read wrong if the gear ratio changed.
Reliability is relative
R.I.P. Ratmonkey
dnuccio is offline
post #6 of 7 Old 04-17-2013, 06:29 PM
Bigdjs123
Or tire size
post #7 of 7 Old 04-17-2013, 07:04 PM
dnuccio
Originally Posted by Bigdjs123 View Post
Or tire size
right
R.I.P. Ratmonkey
dnuccio is offline
