Quantcast 2" Lift Questions.... Wheels and Tires Questions Too!!! - JeepForum.com
EGGERS BROS. INC YOUR JEEP SOURCE
CALL 1-800-274-2460
Competitive pricing!
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > 2" Lift Questions.... Wheels and Tires Questions Too!!!
Old 01-21-2010, 10:57 AM   #1
torchd
Ok I have some questions. First off what size are the stock wheels? I think they are 16x8 or 16x9? And when I bought the Jeep the tires that are on there now are 225/65 or 75/16...
So if I do a 2" lift (don't really want to go bigger) what is the biggest tire that I can fit using my stock wheels? Remember the tire needs to be the same diameter as the OEM tires.
I see that everyone seems to liket eh BFGs A/T tires??? Whats so special about them?
While we are talking about wheels, I really like the WJs wheels. If i get a set, are those directly a bolt on item?
What is the bolt pattern for a ZJ and WJ? Are they both a 5x4.5????
Thanks
torchd is offline   Reply With Quote
Old 01-21-2010, 11:42 AM   #2
bigmike
1995 XJ Cherokee
look in the faq,,all the info is there ,and wj wheels wont fit,,,zj is 5x4.5 and wj is 5x5
bigmike is offline   Reply With Quote
Old 01-21-2010, 11:54 AM   #3
torchd
ok what size are the stock wheels? How big of a tire can go on it with a STOCK lift then????
Old 01-21-2010, 11:56 AM   #4
ArloGuthroJeep
Mr. Hyde!
ArloGuthroJeep's Avatar
1) I think the ZJ would be a 16x7.
2) You can't install a bigger tire, and have it be the same diameter as the OEM tires. Speaking of which, why do you want them the same diameter? To answer what I think you're really asking, with a 2" lift, the easiest tire to fit on there would be a 245/75-16.
3) Everyone likes BFG AT's because they aren't horribly expensive (not cheap though), last a long time, look aggressive, work well when 4-wheeling and in snow, etc...
4) No, WJ wheels won't fit.
5) WJ's are 5x5, ZJ's are 5x4.5
HTH
ArloGuthroJeep is offline   Reply With Quote
Old 01-21-2010, 12:14 PM   #5
torchd
HTH
Thanks for the good info..
1) Yah i thought maybe the stock wheels were either a 16x7 or 16x8
2) When I say same diameter, I mean close to OEM.. For instance on my 2002 Trans Am, OEM tires are 245/50/16 with a diameter of 25.65. I am running 275/40/17 (fronts) and 315/35/17 (rears) the 275 tire is 25.66 diameter and the 315/35/17 tire has a diameter of 25.68... So you can run a bigger tire being the same (or really close) to an OEM tire diameter. The reason you want the diameter the same is bc it won't throw off you speedometer.
3) I may have to get me some BFGs A/T tires.. Like you said they look good and I am sure handle well on wet/dry pavements?
Ok another question. What size tire comes on a 1998 JGCLaredo? Like I said I bought it with a 225/65 or 75/16 tire... I wanted to know what is the biggest tire that can fit on a 7" or 8" rim since we are not sure what size it is. And I will prolly do a BB 2" lift
Thanks for the help
EDIT: doing a search on discount tires website... OEM tires are 225/70/16
Old 01-21-2010, 12:28 PM   #6
ArloGuthroJeep
Mr. Hyde!
Ok, I'll try and say this in a different way.
You can't run a bigger tire and have it be the same diameter. That is like saying you want an orange in a different color, but it has to look the same as it normally does.
Do you mean a wider tire?
In your ZJ you can replace a tiny gear in the transfer case to compensate for the larger tires and thus, make your speedometer correct once again.
The stock size tire is probably a 235/75-16 or about a 30" tire...of course different tire manufacturers actual sizes come out +/- that value.
Old 01-21-2010, 02:25 PM   #7
LordHobbit
Captain Awesome
LordHobbit's Avatar
I think stock zj wheels are 15
93 ZJ 188k 4.0l, IRO 5.5" springs, hpd30 and 8.8 in the shed, waiting on clayton long arms, 4.88 gears, locker ...
If at first you don't succeed, use more speed.
Originally Posted by RhinofiedZJ View Post
Famous last words, "If you had a locker you would of made it"....:D
LordHobbit is offline   Reply With Quote
Old 01-21-2010, 02:26 PM   #8
ArloGuthroJeep
Mr. Hyde!
Some have 16's, some have 15's. He said he is currently running 16" rims which I am assuming are the stock ones.
Old 01-21-2010, 02:29 PM   #9
torchd
I'm almot postive they are 16s..... I will double check after work
Old 01-21-2010, 03:10 PM   #10
LordHobbit
Captain Awesome
LordHobbit's Avatar
okay so TSi models came with 16" for sure. Others came with 15", some possibly with 16".
Old 01-21-2010, 03:30 PM   #11
bandanaboyz
I have owned BFG's before and now I am going to put on Duratracs. 245-75-16 load range 'C'. Supposed to be an amazing tire, check out the thread on the this forum. I am running OME HD springs with MX6 adjustables. If you need shocks and springs, contact Kolak on the board he will get it all together for you.
bandanaboyz is offline   Reply With Quote
Old 01-21-2010, 09:38 PM   #12
torchd
Welp I just checked my tire size. Sorry guys I was mistaken......
I am running 225/75/15
So then the new questions arise.. What size is the stock 15" rim? And on a 2" lift whats the widest tire I can run?
Old 01-22-2010, 03:27 PM   #13
torchd
I just ordered my 2" BB lift, and when it comes to new tires I think I will order 245/70/15s
Old 01-22-2010, 04:35 PM   #14
ArloGuthroJeep
Mr. Hyde!
Most tires meant for a 15" wheel are measured in SAE - ie you could fit a 31x10.5" tire on there, or a 30x9.5" if you wanted something closer to stock.
Glock Forum
