2 inch suspension lift questions? - JeepForum.com
post #1 of 5 Old 11-05-2011, 09:56 AM Thread Starter
lvngtheJEEPlife
so i am investing in a rustys 2 inch suspension lift. i am fairly sure how to do it but once im done with installing the new suspension is there anything else i need to do? concerning the front end? like trac bar or sway bar or tie rod or anything like that? thanks for all the replies on past threads! any response would be great
lvngtheJEEPlife is offline
post #2 of 5 Old 11-05-2011, 10:05 AM
niles6284
I never had to do anything when I had my 2 inch on. just longer shocks. and alighnment.
98 ZJ 4.0 Lifted with stuff
2001 WJ not lifted no stuff
Firefighter/Paramedic
IAFF Local 379
niles6284 is offline
post #3 of 5 Old 11-05-2011, 10:21 AM
Mike97ZJ
Yeah, a 2" lift doesn't really affect anything.
When I did my 2" lift, I didn't even change the stock shocks until much later. It still rode and drove like stock at that point.
Mike97ZJ is offline
post #4 of 5 Old 11-05-2011, 11:24 AM
PolkaPower
You may want to extend your sway bar end links in the front to set your bar back to stock angle. Also think about purchasing two front factory coil isolators and stack them in the front to help level it out more with the rear. I sandwiched my BB in the front and the back is still a little higher.
PolkaPower is offline
post #5 of 5 Old 11-05-2011, 01:46 PM
Mike97ZJ
^^ I like the factory rake.
He could also just leave the rear isolator out to level it out. He'll lose .5" of rear lift, but it's cheaper than a new set of isolators. IIRC they're dealer only and about 35 bucks a pair.
Mike97ZJ is offline
suspension lift
(WJ) 2-Inch “BB” Lift Questions? Ozark WJ Grand Cherokee Forum 72 09-03-2013 09:13 PM
Can 2 inch suspension lift cause springs to over stretch and create a squeek? milesq WK Grand Cherokee & XK Commander Forum 2 07-15-2010 05:15 PM
3 inch suspension lift/ exhaust MARLA21 ZJ Grand Cherokee Forum 2 04-15-2010 10:05 AM
wanted: 4-5 inch suspension lift adamsgrand ZJ Grand Cherokee Forum 15 08-23-2006 11:14 AM
2 and 3 inch lift questions evans1010 ZJ Grand Cherokee Forum 8 04-05-2006 06:05 AM
