2-inch spacer lift on WJ hurts driveline? - JeepForum.com
post #1 of 2 Old 06-30-2004, 08:38 AM Thread Starter
yyjeep
I have just had a 2-inch spacer lift installed on my new WJ, which easily allows 31 tires. This one happens to be by DayStar (which is manufactured locally), but over the years I've successfully used the TerraFlex equivalent on both my TJ and XJ. On a service call to my local Jeep dealer, the service rep said that the lift is putting stress on my driveline and is causing a noise (which I haven't heard) and will cause premature U-joint and/or transmission failure. He says that the suspension design on the WJ won't accommodate this kind of lift. (Of course, the dealer will install a "proper" 3-inch lift for me for approx $3000).
Has anybody else heard this story? Is there any evidence of failures with this kind of lift? If so, is there any kind of fix? I'm astounded that Jeep would tell me that my supposedly "Trail Rated" Jeep suspension is so delicate that it can't handle the slight angle caused by this lift. Imagine what would happen if I actually took it off road???
Thanks
yyjeep is offline
post #2 of 2 Old 06-30-2004, 12:51 PM
PlatinumZJ
Senior Moment Member
PlatinumZJ's Avatar
Originally Posted by yyjeep
... He says that the suspension design on the WJ won't accommodate this kind of lift. (Of course, the dealer will install a "proper" 3-inch lift for me for approx $3000).
Thanks
Sounds like a load of BS to me. But He has to feed his family too , give him a break and get the "proper" lift installed
Doug
When all is said and done, more is said than done.
Platinum '97 ZJ LTD, I6 (see profile) Paid for!
Links:
for ZJ & WJ stuff,
for performance stuff. I6 performance info at
Other stuff: Kevin's Roof Rack. KOR sliders, Bored 62mm TB, Blaupunkt Bermuda w/ ipod, Brembo Slotted rotors,
OME steering stabilizer, H4 headlight upgrade...
PlatinumZJ is offline
2 inch spacer installation DEUJEEP ZJ Grand Cherokee Forum 3 06-12-2009 07:54 PM
3 inch Fat Bob spacer lift....reason not too 95laredokid ZJ Grand Cherokee Forum 7 04-01-2009 03:55 PM
questions about 2' inch spacer Walte464 ZJ Grand Cherokee Forum 5 04-01-2008 01:15 PM
3 inch spacer lift Izzy ZJ Grand Cherokee Forum 4 12-17-2007 11:30 AM
2 inch spacer lift?? Krawlfish ZJ Grand Cherokee Forum 4 03-12-2005 08:48 AM
