2" bb kit shock size question - JeepForum.com
post #1 of 3 Old 09-22-2009, 12:17 AM Thread Starter
ronsaun
2003 WJ
installed 2" bb 03 wj. may need shocks now. since they have to be longer how are the parts guys going to know which ones will fit since they wont be stock?
ronsaun is offline
post #2 of 3 Old 09-22-2009, 01:11 AM
WiCkeDuDe
WiCkeDuDe's Avatar
Usually all the aftermarket shocks will have a stock length and then a shock 2" longer, maybe 4" etc. The dealer is not going to have anything longer. Check application guides online to find part numbers for the shocks you want. Talk to Kolak as well. He is alot of help and has seen them all.
I Have WJ Stuff for Sale
WiCkeDuDe is offline
post #3 of 3 Old 09-22-2009, 10:11 PM
ARFuniN
Check with Kevin and his Team at KOR...Check Grand Cherokee Wrangler Cherokee Consultation Forum - Hard-KOR.
They will have you install the BB and then take hub center to fender measurements (HF) at all four corners. Should be somewhere between 19.5" and 20.5" with a BB and stock spring sag. They will recommend shocks based on the HF you supply.
I ordered my shocks from him so the consulting fee was $0 and also got the rear shock bushing kit.
With the stock shocks and a 2" BB I drove around for a month and a half (on pavement) until I got the shocks sorted out. The only thing I noticed was that the shocks seemed to be limited in droop when going over speedbumps.
ARFuniN is offline
"tire size", feel stupid asking this question... lakailimited06 ZJ Grand Cherokee Forum 3 12-06-2009 11:57 AM
What size shock to run with a 2.5" coil? gmp211 ZJ Grand Cherokee Forum 3 06-01-2009 02:23 PM
3" IRO WJ's, tire size question TheSandman ZJ Grand Cherokee Forum 1 10-23-2007 07:38 AM
KOR BB to IRO 3" shock question Eshindi ZJ Grand Cherokee Forum 3 09-16-2007 08:30 PM
Shock Size JeepingOverYou ZJ Grand Cherokee Forum 5 03-24-2005 10:09 PM
