2" BB install - JeepForum.com
post #1 of 22 Old 04-25-2013, 08:02 PM Thread Starter
KyleD31
2" BB install
Okay, I know there are many threads on this and I have read most of them as well as the FAQ, but I still have a couple questions.
I hopefully will put the lift on this weekend, I gave myself friday, saturday, and sunday to do it which i know is plenty of time
I know that it is recommended to extend the coil retaining posts and bumpstops, and get longer shocks, however i know i do not HAVE to. I will be running stock shocks (for now). Now this is where my questions come in.
1. Where do i epoxy the exhaust tubing for the coil retaining post? how long does the exhaust tubing have to be? And what diameter should it be? ill be keeping the stock swaybar links so if it is too complicated then i know ill still be safe without doing so.
2. How do i extend the bumpstops? I have heard you can use hockey pucks but I'm unsure how to put them on. If anybody has pictures that would be great.
KyleD31 is offline
post #2 of 22 Old 04-25-2013, 10:36 PM
capcyclone
capcyclone's Avatar
I asked a similar question to your #2...I'm wondering how much space you need to fill with the pucks for the 2" bb. I assume just one puck since they are individually about 2"?
Hopefully someone can answer your questions (and mine).
"The Jeep is America's only real sports car" - Enzo Ferrari
'98 Jeep GC 5.2L "ZJ" - Sold
'02 Jeep GC 4.7L HO "WJ" - Daily driver
capcyclone is offline
post #3 of 22 Old 04-26-2013, 07:58 AM
PolkaPower
You have to measure yourself and see. Compress one side of the axle and see if the tire is going to hit the fender up in the wheel well. If it's not then no need for hockey pucks. If you have larger tires you may or may not need to add one or two.You won't know until you measure. They work in the front only. I slipped them between the coil and RTV'd one to the coil perch.
PolkaPower is online now
post #4 of 22 Old 04-26-2013, 08:06 AM Thread Starter
KyleD31
How do I attach them? And do you have pictures? I'll be running 31s
KyleD31 is offline
post #5 of 22 Old 04-26-2013, 08:14 AM
PolkaPower
You just use something like Permatex RTV and squirt some on the spring perch and stick it down. I don't have any pics. There are plenty of threads about this and pics on google http://www.jeepforum.com/forum/f13/f...-them-1370147/
post #6 of 22 Old 04-26-2013, 09:13 AM
capcyclone
capcyclone's Avatar
Excellent info and answers - thanks man!
post #7 of 22 Old 04-26-2013, 09:42 AM Thread Starter
KyleD31
Thanks a lot!
KyleD31 is offline
post #8 of 22 Old 04-26-2013, 09:54 AM
PolkaPower
Originally Posted by KyleD31 View Post
Thanks a lot!
Just clean the coil perch off and stick it on with RTV takes a few minutes. You want to see how many you need though so measure for sure. Either way it's not permanent so no worries.
post #9 of 22 Old 04-26-2013, 09:57 AM Thread Starter
KyleD31
And to measure, flex it all the way, then what do I measure exactly?
KyleD31 is offline
post #10 of 22 Old 04-26-2013, 09:59 AM
Myusername1674
I threw two pucks in each side on mine, and jb welded them in.
As for the retainer post, read this link, scroll about halfway down I did a little write up ish of what to do.
95 FiveTwo ZJ, DD, Lifted, Locked on 35s,
(in progress)
Myusername1674 is offline
post #11 of 22 Old 04-26-2013, 10:11 AM
PolkaPower
Well if the stock bumpstop isn't bottomed out and the tire is hitting then you need to see how many pucks you need to add to stop the tire from hitting inside the wheel well. You want the bumpstop to hit before the tire does.
post #12 of 22 Old 04-26-2013, 10:26 AM Thread Starter
KyleD31
Okay I understand. Thanks! I'll take a bunch of pictures of the install
KyleD31 is offline
post #13 of 22 Old 04-26-2013, 10:27 AM Thread Starter
KyleD31
This helps a lot, thanks!
KyleD31 is offline
post #14 of 22 Old 04-26-2013, 01:10 PM Thread Starter
KyleD31
Do I have to extend the rear bumpstops using a different method or not at all?
KyleD31 is offline
post #15 of 22 Old 04-26-2013, 03:00 PM
PolkaPower
For 2" you really don't need too. Here is a pic of mine stuffed with stock bump stops. Never rubbed.
