2" BB and 31's worth the cost off road? - JeepForum.com
post #1 of 32 Old 06-12-2013, 09:09 AM Thread Starter
L_Kilkenny
Fairly basic question, as always money is tight but the ZJ is gonna get tires soon. I was all set on a 2" BB and 31's but re-gearing is not an option at this time.
- '98 4.0 ZJ, untouched factory LSD.
- Winter DD/Hunting/Occasional play rig (Mostly mud but also hills and gullies). Throw in an annual trip out west.
I'm starting to think that just stickin with 235/75's and throwing in a TrueTrac would be money better spent.
What say you?
LK
L_Kilkenny is offline
post #2 of 32 Old 06-12-2013, 09:18 AM
PolkaPower
You are probably right. The 4.0 will be a dog with 31's also.
PolkaPower is online now
post #3 of 32 Old 06-12-2013, 12:04 PM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
Go with 30s and have some fun.
04 4.7 HO, limited
08 Z71 Suburban, front leveling kit with rear spacers. 285/65 18s Nitto TerraGrappler G2s
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
For your performance needs:
480.998.366
Texas ZJ1 is offline
post #4 of 32 Old 06-12-2013, 01:04 PM
Myusername1674
If you had the v8 i'd say go for it! Mine on 31s can go lotsa places i didnt expect it too. Idk about the 4.slow though.
Sent from my couch using JeepForum app
95 FiveTwo ZJ, DD, Lifted, Locked on 35s,
(in progress)
Myusername1674 is offline
post #5 of 32 Old 06-12-2013, 01:16 PM
ROFLwaffles
I keep hearing people talk about re-gearing. Is that advice for people with 3.55 gears in order to not drive like a pig with 31s?
My ZJ is a 4.0, and it came with 3.73 gears. Is that sufficient to run 31s properly? Or do I really NEED to go higher? Like 4.10?
ROFLwaffles is offline
post #6 of 32 Old 06-12-2013, 01:19 PM
Superfuman
My ZJ is a 4.0, and it came with 3.73 gears. Is that sufficient to run 31s properly? Or do I really NEED to go higher? Like 4.11?
Honestly, 3.73 or 3.55 with the 4.0 and 31s isn't really too too terrible. 4.10 is recommended for 31s, but it'll be live-able with 3.73. But put a regear on you to-do list.
2000 TJ - JB Headers FM Super 44. RC 3.25'' on 31s.
Superfuman is offline
post #7 of 32 Old 06-12-2013, 04:40 PM
zlieberman
budeget boost
Go for the budget boost on 31.
I had a 97 4.0 select track with 3.73 gears and a d44a that I swapped in with an aussie locker, budget boost and 31's. That jeep would scream, motor was stock and was way faster than any other 4.0 I've driven. It would cruise down the high way at 75-80 no problem.
zlieberman is offline
post #8 of 32 Old 06-12-2013, 05:40 PM
underpowered
Bouncin' on a Budget
underpowered's Avatar
31's and a 4.0 is not bad at all. IMO 3.55 gears are decent for 31's. there are vehicles that come with worse gearing from the factory.
i have no issues with my 4.0, 31's and 3.55 gears been running it for years. the extra ground clearance is worth it for sure.
1998 ZJ-- lowered a touch
2005 GMC 2500HD 496 C.I.
Fat Amy-1989 K5 blazer. Linked, lifted, 38.5's on won tons. Big Girls can play in the woods too.
underpowered is offline
post #9 of 32 Old 06-12-2013, 09:47 PM
Myusername1674
Take this guys word, you wouldnt think the extra few inches would help a ton, but it comes in handy all the time.
(in progress)
post #10 of 32 Old 06-13-2013, 01:06 AM
kg6mov
Hears the voices
kg6mov's Avatar
I'm a V8 but 31's are plenty for a lot of trails. I surprise the hell out of the wranglers I run with because they're all on 35's and 37's.
kg6mov is offline
post #11 of 32 Old 06-13-2013, 08:04 AM
98LIZJ
I have 31s with a 2" BB with the 4.0 and I won't say it's terrible but it DEFINITELY a dog. I also needed new track bars and sway bars so Its not as cheap as you may think. On the other hand it is alot better on the trails.
98LIZJ is offline
post #12 of 32 Old 06-13-2013, 08:29 AM Thread Starter
L_Kilkenny
Don't doubt this a bit. Every 4x4 I've had ran 31's or metric equivalent or bigger. One of the reasons I wanted 31's on the ZJ. But I already have one truck that won't consistently hold in OD going up the slightest grade or into a head wind when going down the interstate. Forget about it if you crank the knob for AC. Don't want the ZJ to do the same "if" the TrueTrac is gonna be an equivalent or better mod. Not worried so much about gearing and offroad. I can't recall running into anything that 4low wouldn't handle even if I was lacking some power. That's stuff just isn't around here.
I like the 4.0 as I've stated many times. For what I do I wouldn't trade it for a V8 but even I have to admit it's not a powerhouse.
post #13 of 32 Old 06-13-2013, 08:44 AM
dnuccio
2in bb and 31s will get you very far. i have a BB and 30s and i kept up with a 2012 wrangler rubicon, wasnt a hard trail but there was a spot he had to back up and try again.
Reliability is relative
R.I.P. Ratmonkey
dnuccio is offline
post #14 of 32 Old 06-13-2013, 10:07 AM
WhiteOut
WhiteOut's Avatar
Anyone that psots up saying that their BB'd ZJ kept up with, and did better than, a whatever on 35s/37s should be required to show pictures of said trail and said line that they did better than the other Jeep.
WhiteOut is offline
post #15 of 32 Old 06-13-2013, 10:22 AM
PolkaPower
I still think a locked stock height ZJ on 30's with skids would out wheel a BB ZJ open with 31's with skids.
