2"BB 245/75/r16's or 265/70/r16's help... - JeepForum.com
post #1 of 16 Old 03-24-2009, 09:02 PM Thread Starter
chonger
Hey I just finished a nice 2"BB with RE monotubes. I was wondering what are the reasons to choose either of the above tires sizes. I see many people with the same lift height use both sizes of tires. What are the real differences I can expect from either choice?
Thanks,
Chris
chonger is offline
post #2 of 16 Old 03-24-2009, 09:28 PM
GraKee99
Rapist Wit
GraKee99's Avatar
One is wider.
Brian
WJ, WK, CJ5
GraKee99 is offline
post #3 of 16 Old 03-24-2009, 09:43 PM Thread Starter
chonger
Well i was looking for advantages on and off-road as well as fitament issues with a 2"bb...but thanks anyhow...
chonger is offline
post #4 of 16 Old 03-24-2009, 09:49 PM
rustynail
Wider is better on and off the road up to at least 10 1/2" which is about 265. I would go with either 265 70's or 265 75's if you like off roading.
- Russ
5.9 ORVIS 33x12.5 MTR-Kevlar, 7" fr adj IR LA's, 7" rr adj RE SF SA's, adj JKS TB's, RE SB disc, RE Springs, JKS ACOS, 13" RS9000XL's, OME SS, NP231, Durango box, IR Sliders, IR Skid, 3" Flowmaster 70, K&N, Superwinch EPi9.0, Optima Yel, 2 air comp, Alpine, Garmin, Sunroof
rustynail is offline
post #5 of 16 Old 03-24-2009, 11:01 PM
GraKee99
Rapist Wit
GraKee99's Avatar
A 265/75/16 won't fit a BB without quite a bit of trimming.
Brian
WJ, WK, CJ5
GraKee99 is offline
post #6 of 16 Old 03-25-2009, 12:05 AM
SocalWJ
Here is an article that would disagree with the above statement. It's really all going to come down to what conditions you are going to be driving in. Some are going to say wider is better and other are going to say tall and skinny is better.
http://www.expeditionswest.com/resea...tion_rev1.html
John
'04 Laredo 4x4 select-trac 4.0L
2.5" BB w/ MX6 shocks
Addco Rear sway bar w/ IRO extended links
SocalWJ is offline
post #7 of 16 Old 03-25-2009, 12:33 AM
rustynail
That is a sweet article. I don't know how I was quoted with the rest of the sentence removed but that's pretty tricky. Anyhow the 70 series will handle on the street a lot better. My 2wd suburban has 235 75 15's stock and I put 265 70 15's on there (same height) and corners awesome now, no more white knuckles on the winding mountain roads.
- Russ
post #8 of 16 Old 03-25-2009, 02:50 AM
EarpWJ
How much does it really make a difference? A lot of tires don't come in 265/70/16 (ie KM2 and GY duratrac) I was thinking of getting the duratrac 245/75/16, but its still a daily driver and cant have the thing handle like crap...
EarpWJ is offline
post #9 of 16 Old 03-25-2009, 04:05 AM
kreso
2010 WK
I have on my 2" 235/85-16 and no rubbing at all.
kreso is offline
post #10 of 16 Old 03-25-2009, 05:33 AM
586ZJ
I had 265/75 16 Cooper Discoverer STT's on my stock height ZJ, yes they rubbed before lock and I never really wheeled them. But I did a 3.5 IRO and they barely rub now. With a BB I think it would be fine and look damn good too.
586ZJ is offline
post #11 of 16 Old 03-25-2009, 10:34 AM
JustSomeDude
You're basically looking at 9.5" wide by 30.5" diameter tires, versus 10.5" wide by 31" diameter tires. The diameter obviously affects whether or not you need to trim. I just installed the 245/75s on my 2" BB with RE mototubes, and have no rubbing. I would probably have some minor rubbing with the 31s.
However, the bigger issue is the width of the tire with respect to your intended use. The main difference between 9.5" wide and 10.5" wide tires will be snow performance. Due to the increased contact area between the tire and the road on 10.5" tires, there will be less surface pressure placed on the road by the tire. As such, wider tires tend to "float" on snow - resulting in "spinning" - and obviously reduced traction/poor winter performance.
So - what is your goal?
My WJ is my daily driver. I like being able to travel in snow, especially into the mountains for snowboard trips. When people are hung up on the side of the road and spinning around in a snowstorm, it's fun being able to pass them by with stellar traction. Will my off-road performance be slightly reduced? Yes - but then again with only a 2" BB, it's not like I'm looking for aggro-articulation, and airing down my tires to 14 PSI. My off-roading is limited to moderate trails, and weekend warrior stuff. The 9.5" wide tires allow me to cover all the terrain that I NEED, while giving me optimum winter performance.
If you are looking to try a little more off-roading, the 10.5" wide tire may be right for you -- but then, the 2" BB will not satisfy your wheeling itch for very long. If you just want a good all-around vehicle, that rocks in all weather/road conditions... stick to the 9.5s.
2004 Jeep Grand Cherokee Laredo
3" IRO Lift Kit | Bilstein 5125 Shocks | JKS discos | JKS BPEs | IRO Adj Track Bar
Goodyear Duratrac 265/75/16
JustSomeDude is offline
post #12 of 16 Old 06-21-2009, 10:28 PM
rw1978
JustSomeDude-
Can I see a pic of your ride? I'm looking at doing something very similar on my '99 Limited.
Thanks
rw1978 is offline
post #13 of 16 Old 06-17-2015, 01:31 PM
Krasulo1
you literally could not have been more informative, good on ya
Krasulo1 is offline
post #14 of 16 Old 06-19-2015, 09:59 PM
jswerve
6 year old thread lol
1998 5.9 |3.5" IRO lift w/adj CA and track bars | Bilstein 5100 | TJ Rubi wheels 245/75/16
jswerve is offline
post #15 of 16 Old 06-20-2015, 12:38 AM
torchd
2003 WJ
I am running on BB lift the same tire' 245/75/16. Barely had to trim my front bumper.
The 265/70/16 is .75" wider than the 245/75/16 tire. I wouldn't think there would need that much more trimming.
245/75/16 = 30.47" tire
265/70/16 = 30.61"
and I just realized this thread is ancient lol
1998 Jeep Grand Cherokee Laredo
2" BB Pucks | SkyJacker Hydro Shocks | Rubicon Wheels | Cooper 245/75/16 Tires
2002 Trans Am
Cam, Full Exhaust, Stock Heads, Stock LS6 Intake and Stock 10 bolt with 3.42s
420 RWHP and 382 RWHTQ
torchd is offline
2"BB How much wheel backspacing for 265/70/R16's? chonger ZJ Grand Cherokee Forum 1 03-19-2009 10:34 PM
255/70/r16's wj03grandy ZJ Grand Cherokee Forum 2 08-26-2008 07:04 PM
Just got a set of 245/75/R16's Ned97sahara ZJ Grand Cherokee Forum 15 06-04-2005 06:53 AM
Anyone have a WJ GC with 255 70 R16's guns2323 ZJ Grand Cherokee Forum 1 08-30-2004 12:45 PM
Tire Question! 97 ZJ to 00 WJ. Ok to put 225/70/R16's on the 00? tjanousek ZJ Grand Cherokee Forum 1 04-23-2003 05:03 PM
