01-06-2006, 07:44 AM
#1
So I tried the search feature and I just couldn't get the right words in. So here goes.
If I go from a 2" BB, can I just get 2 new OME 2" longer front springs, and do a F>R swap and gain another 2" of spring lift, and have my 2" BB lift. Is there anything else that needs to be done to go up to 4" of lift? I'm getting things like lower the Tcase, track bars, control arms, brake lines. I'd just like the down and dirty, and why I need to do any other mods when going from 2" to 4" of lift.
2006 Trail Rated Limited Commander ~ 5.7L Hemi ~ 62k miles
01-06-2006, 07:59 AM
#2
You can't do a front to rear swap on a WJ the springs are different diameter.No TC drop is required nor brake lines.Not track bars but trackbar for the front only,adjustable one ofcourse.Going from 2" to 4" does get a bit pricey but well worth it.You may have to get a custom front driveshaft if you have the boot style one up front.That is very important and could be dangerous if you have the wrong style because it will bust at any time at that height.It could bust in one day or 4 months but it will bust anywhere,you don't have to be wheeling for it to bust.
01-06-2006, 08:09 AM
#3
Mr. Hyde!
No need to lower the tcase.
Adjustable track bar, springs, control arms, rear A-arm spacer are the things that come to mind. Not sure if you need longer brake lines at 4" or not
01-06-2006, 08:13 AM
#4
You can go upto 6" with the stock brake lines.So no need for brake lines at 4".
01-06-2006, 08:24 AM
#5
So since that is over my head in technical terms of getting a new driveshaft, Adjustable track bar, springs, control arms, rear A-arm spacer. The only thing familiar with that is the springs for me. I thought if I couldn't do a F>R sway then I could just get 4 new OME 2" springs, and still use my BB, but if I have to do all that other stuff.. its going to stay at 2" =( =(
01-06-2006, 08:28 AM
#6
You say that now but once that jeep bug it's you harder you will change your mind and jump up to 4".
01-06-2006, 08:30 AM
#7
Mr. Hyde!
Can do a little at a time, buy the track bar and install it. Can ptu the A-arm spacer on with just the 2" BB (my local 4x4 shop does that for all 2" installs on WJ's  ), and if you opt for adjustable control arms can do that before you finally put on longer springs....
01-06-2006, 12:52 PM
#8
I ate what?
I've got the same setup your talking about, I went through Nick (kolak@aol.com) he will piece it together for you based on what you have. Best thing I've done for my WJ yet, you will not regret it.
Basically you don't have to have control arms yet, I'm still running stock ones for now and I wheel mine. Here's a list of when Nick told me I would need to wheel it safely:
- Shocks - DT3000's will run you about $150, Bilsteins about $300
- OME Springs (keeping the BB)
- Rear A-Arm spacer
- JKS Quick Disco's (I already had these)
- JKS Adj Trackbar
- OME Steering Stabilizer w/ WJ mounting kit (already had this too)
- Extended rear swaybar endlinks
- Extended Bumpstops (Front and Rear)
Optional add-on's later for better ride and less body roll:
- Rear 1" Addco Swaybar
- Front and Rear Upper and Lower Control Arms
Like Arlo said, you can buy most of it piece by piece and add certain things to what you already have and then get the big stuff when you have the cash.
Ken
99 GC Limited - 4.7L HO V8, 6.5" IRO HC LA lift, F&R D44s locked & trussed, 242HD, IRO TC Skid, KMA Bumper, 35's
2006 Saturn Redline -2.0L Eaton supercharged I4, GMPP Stage 2, Custom Tune, AEM CAI, Ebiach Pro Kit w/ swaybars, EVO Ventus V12s (13.76 @ 103.85)
2006 Pontiac G6 GTP
2012 Nissan Juke - (hers)
2000 SV650 - naked, integrated tail light, sliders, corbin, pilot roads, RK chain & sprokets, D&D full exhaust, FactoryPro Stage I jet kit, +4 Ignition Advancer, Barnett race clutch
2006 Triumph America 900 - Full Dresser
January 2009 Grand Cherokee of the Month (GCOTM)
01-06-2006, 03:01 PM
#9
Ramon, and I have almost exact set up mine rides great as well.
4.5"springs not 2.5 springs + 2"BB i had, Hecthethorn shocks, extended bumpstops for 2", custom drive shaft, rear end links, front Teraflex quick disco, JKS adj trac bar, stock control arms.
Hope it helps
