2.25" spacers - JeepForum.com
post #1 of 17 Old 08-23-2011, 10:25 PM Thread Starter
mojop79
2.25" spacers
Found a set of four poly spacers, one piece from 4wheelcustoms.com I'm interested in buying. anyone know of this company or their spacers?
mojop79 is offline
post #2 of 17 Old 08-23-2011, 11:30 PM
fisher1630
dont do it, I bought the set of 4 for my jeep a few months ago. Went to put it in last week, and they did not fit properly in the back. The spring just did not sit right on the spacer. They fit the fronts perfect though. I bought fat bobs spacers for the back and they fit like a glove.
fisher1630 is offline
post #3 of 17 Old 08-24-2011, 06:24 AM
AlphaLorde
I had no issues installing mine. The hole at the top of the rear spring is a hair smaller then the spacer.
When installing I just had to get the weight of the truck on it and the spacer slid right in. Been running em for over a year now.
To each their own...
1998 ZJ Laredo 5.2L 139k 231 w/SYE artec trussed 8.8 4.25"F/5"R lift
AlphaLorde is offline
post #4 of 17 Old 08-24-2011, 07:17 AM
blackjack12982
1994 ZJ
The first time I installed my BB the rear didn't fit correctly either. I don't know what brand they were, they were used. But they're made of polyurethane, not freaking titanium. The rear spacer hole was a few mm's too small. 3 minutes with a knife and they fit perfectly.
A poly spacer is a poly spacer, they're all the same.
blackjack12982 is offline
post #5 of 17 Old 08-24-2011, 07:40 AM
sabzz
Spend the extra money and get a RC or IRO 3.5 inch F>R kit. 400 for RC shipped to your door from jeep4x4center.com or around 500 shipped for IRO to your front door.
1998 ZJ 4.0 work in progress/DD
'97 ZJ 4.0|3.5 RC|31" -SOLD
sabzz is offline
post #6 of 17 Old 08-24-2011, 07:40 AM
KillaJeep4569
2006 WK
These are what I used, and Poly Spacers are NOT poly spacers. They are not all the same, each has different hardners and such inside, to save money and make things cheaper. Take a look at these, and they stay a TRUE 2.25" and dont depleate or loose strength after time.
http://www.4wheelcustoms.com/Products.asp?Cat=1210
KillaJeep4569 is offline
post #7 of 17 Old 08-24-2011, 07:43 AM
blackjack12982
1994 ZJ
Did you do testing on them to see the hardeners? Or did you just believe the website where it say "High quality"? I've seen at least 4 different sets of spacers, and short of the color were the same.
post #8 of 17 Old 08-24-2011, 07:45 AM
KillaJeep4569
2006 WK
Tested them out, with a Wieght at the Shop, If you need photos Ill post some of my truck.
They are not all the same, You can believe what you want or what you hear. I have tested and these are what I went with. You go with a 2" BB lift it will be 1.75 after install Gaurentee. These stayed 2.25" before and after install and still going 2.25 after months.
post #9 of 17 Old 08-24-2011, 07:48 AM
blackjack12982
1994 ZJ
I find it absolutely implausible that you tested every different set of spacers. Congratulations, your spacers for months stayed the same height, they all will. GTFO of here with your "guarantee".
post #10 of 17 Old 08-24-2011, 07:51 AM
KillaJeep4569
2006 WK
I bought about 5 kits and tested them out, all I know I found these to be the best and stayed TRUE.
post #11 of 17 Old 08-24-2011, 07:52 AM
KillaJeep4569
2006 WK
Also there is no need for you to Cuss me out, Not my fault you dont believe me. You can do what you want. I have and know the truth. Anyone else like the info you can PM me,
Internet Gangsters! Gotta love them!
post #12 of 17 Old 08-24-2011, 07:53 AM
blackjack12982
1994 ZJ
post #13 of 17 Old 08-24-2011, 08:27 AM
fisher1630
do a search on here, I am not the only one to complain about 4wheel customs 2.25" lift. Sure you can screw with the spacers and shave a little off here and custom fit it. My question is why, you can buy different spacers that are exact fits with no slop. To each his own.
post #14 of 17 Old 08-24-2011, 09:21 AM
blackjack12982
1994 ZJ
I'm not defending them, I have no horse in this race. I'm just saying that you went through alot of hassle buying them, returning them, and then buying another set, when the first set would've worked.
I can understand sending them back to make a point, but 4Wheel Customs isn't going to change their manufacturing processes just because they didn't fit on your ZJ.
post #15 of 17 Old 08-24-2011, 12:19 PM Thread Starter
mojop79
That's the spacers I was referring to in my original post.
mojop79 is offline
