2.25" budget lift? - JeepForum.com
post #1 of 9 Old 03-29-2013, 07:45 PM Thread Starter
AMCJAVELIN
1994 ZJ
2.25" budget lift?
for right now instead of spending a boatload of money in the 2.25" lift other than the after installing the plastic spacers and new shocks is there any other modification that has to be done to the suspension and would it comfortably run a 30" tire off roading?
AMCJAVELIN is offline
post #2 of 9 Old 03-30-2013, 07:02 AM
Foundrydude
If you're really going to off road it, and have nice fenders/bumpers- extended bump stops
It kind of depends how wide the tire is, and how the rim fits. Stock tires are 29", so 30 isn't much taller. If it's on an 8 inch wide custom wheel that half sticks out of the fenders, then the extended stops come into play because you've got to clear the fender lips.
If it's on a stock rim and the tires aren't very wide, probably don't need the extended stops. They'll tuck up into the fenders and clear the lip
My tires are 30x9 on stock wheels with a 2 inch BB and they look kind of lost in the wheelwells. Go for 31s.
good luck with the project
Foundrydude is offline
post #3 of 9 Old 03-30-2013, 07:42 AM
Cherokee95kid
Here's my Zj with 2.25" bb and 235-75-15s I'd like 31s but I have a lot of life in these yet. I didn't bumpstop anything I just extended my rear spring retainer so I don't drop a spring. I didn't disconnect the sway bars for the flex shots. And hopefully you can see the extended spring retainer in the one pic.
Cherokee95kid is offline
post #4 of 9 Old 03-30-2013, 07:42 AM
Cherokee95kid
Flex shot 1
post #5 of 9 Old 03-30-2013, 07:43 AM
Cherokee95kid
Flex shot 2
post #6 of 9 Old 03-30-2013, 07:43 AM
Cherokee95kid
Rear spring retainer
post #7 of 9 Old 03-30-2013, 08:28 AM
AnotherRedZj
Stock rims, no spacers (besides steering stops). 31x10.50's, minor (less then 1") trimmed to lower front bumper,
AnotherRedZj is offline
post #8 of 9 Old 03-30-2013, 10:09 AM
BigJohn96ZJ
2.25" bb+ stock isolators, 31x10.50 km2, everything else stock.only rub at full lock.
Next to a 04 f250 9"lift bald 37s
Flex shots
96 ZJ Laredo 4x4, 5.2l, 2.25" budget boost, 31 bfg m/t KM2
BigJohn96ZJ is offline
post #9 of 9 Old 03-30-2013, 10:40 AM
AnotherRedZj
Flex shots
Forgot to mention I have stock isolaters also,
Big john, two washers in The steering stops should solve your full lock rub! 5min fix
