2-1/2" lift - JeepForum.com
post #1 of 10 Old 09-09-2004, 12:59 PM Thread Starter
Bilal
2-1/2" lift
I'm putting a 2-1/2" lift on my jeep from kevinsoffroad.com. It's a 94 Laredo. Do i need anything else besides the spacers and bump stops? What do i need to install it?
Bilal is offline
post #2 of 10 Old 09-09-2004, 02:19 PM
KillerZJ
KillerZJ's Avatar
You may want shocks, but all you need is hand tools.
Looking for E36 325i(s) 5 speed only. Jeep is for sale $3,000 takes it. E-mail only.
*Sale Pending*
Wow no pictures in sig? F*cking gay.
KillerZJ is offline
post #3 of 10 Old 09-09-2004, 02:24 PM Thread Starter
Bilal
I heard I need a spring compressor. true or false?
and what do bumpstops do? Do I need them?
Bilal is offline
post #4 of 10 Old 09-09-2004, 07:12 PM
KillerZJ
KillerZJ's Avatar
hell no you wont need spring compressor. I put on 3" springs and 1.75" spacers without compressors. You dont need bumpstops. Do you wheel hard? I'm assuming you will get 31's?
*Sale Pending*
KillerZJ is offline
post #5 of 10 Old 09-09-2004, 07:49 PM Thread Starter
Bilal
nah, i dont wheel at all. i busted up a s10 blazer a few years back so none of that for me. but i still like the look. but what exactly do bumpstops do?
Bilal is offline
post #6 of 10 Old 09-09-2004, 08:13 PM
KillerZJ
KillerZJ's Avatar
stop up-travel. dont get them.
*Sale Pending*
KillerZJ is offline
post #7 of 10 Old 09-10-2004, 03:40 AM
shadetree
bilal,
i just installed kevins 2.125 budget boost and here are some tips for you. to the rest of you sorry but i disagree with you input.
reccomended tools for installing lift kit:
1. tall and wide base jack stands
2. spring compressors (outside ones for struts) you can pick these up at pep boys. basically you pay full price and then get a full refund upon return. (tell them before purchasing that this is a rental)
3. a breaker bar (optional, i didn't have one)
4. liquid wrench or pb blaster (penetrant) this is a must. spray all bolts/nuts once or twice prior to even turning a wrench.
5. a 2.5-5 ton floor jack is needed also.
our jeeps have metric and standard bolts so keeping that in mind you should have in your garage already an assortment of each in sockets and open ended wrenches.
some pointers from me to you.
1. only do one side at a time.
2. remember even when using spring compressors it will be tight getting your springs back in with the added 2" . i didn't disconnect my lower control arms but i did have to push down on the axle.
3. shocks disconnected from the lower end also.
4. your front end should have the bump stops, i bought the acos system and they have bump stops built in.
5. when i started to put my acos in i realized through trial and error that the soft oem stopper is crimped in from the top side of it. what i had to do is wedge a screwdriver in and wedge it out then you can get to the bolt that will allow you to take your oem bump stop out. once you do this there is no going stock again!
6. on the back i didn't use the bump stops because i would have had to cut my oem ones off of the frame in order to bolt up the new ones with the longer bolts provided. (which would have been easy if i had a sazall) i now own one after the fact!
7. i do reccomend getting the rear spring retainers.
8. when istalling these *don't use rtv!! it don't hold them in! instead slide it in and mark a spot for you to drill a hole for a sheet metal screw that will go through the existing metal. when you do drill this hole ensure that you countersink the edge with a larger drill bit so your screw head won't stick out and rip up your 2" spacer.
9. i do reccomend you also replace your oem steering stabilizer. i bought "old man emu" the install was very easy. you will need a tie rod end puller (again go to pep boys) "don't rest your head underneath when popping it loose either"
10. the new steering stabilizer whatever brand you buy will usually only fit one way. i found out by switching it around till i realized the amount of space inbetween your bushings and the mount. at first i was looking at the box it came in, i was back on the net looking at readers rides but none were clear.
11. (this was an edit) on the front i also disconnected the brake line bracket while i was down there disconnecting the lower end of my shocks. NOTE: don't break the integrity of your brake lines or you will need to bleed them afterwards.
well this is long enough if you have questions during install then pm me or email me cotys513@yahoo.com
or
(928) 317-2877 ask for scott and let me know who you are ie.. so and so from jeepforum.
"If I can't buy it or borrow it, I don't need it"
-1994 ZJ Lifted and Locked...
-1983 CJ7 4.2ltr/Dana 300/Warn F&R bumpers...and some other goodies.
D.W.A. (Death Wobble Anonymous)
shadetree is offline
post #8 of 10 Old 09-10-2004, 11:19 PM
KillerZJ
KillerZJ's Avatar
Oh get real. You dont need bumpstops or rear spring retainers. He isn't wheeling it. And for the jacks/stands, that was pretty much a known fact for bilal I hope. I did my lift with socket set and sockets. Thats all. No wrenches or air tools or anything.
*Sale Pending*
KillerZJ is offline
post #9 of 10 Old 09-12-2004, 05:48 PM
shadetree
killerZJ,
first off i would like to compliment you on your jeep. it looks good.
however i have no idea who bilal is! i did searches on here prior to doing my lift and i still had those tips written down. maybe you should come up with a scale to compare your mechanical skills with everyone else's. once you do come up with some sort of universal scale to measure mechanical ability and we use "your ability" as a grading curve then everyone can guage their own ability and either get a reality check on what they know or everyone will get a boost in confidence. (IF) you do all of this then maybe i'll "get real"
post #10 of 10 Old 09-12-2004, 10:35 PM
Dacaur
Dacaur's Avatar
2008 MK Patriot
As for spring compressors, you dont NEED them, but they make it a LOT easier. Its not like they cost you anything, if you dont have a pep boys, stop by a napa auto parts, they also rent spring compessors, you pay $75, then get a full refund when you bring 'them back.
Its true you dont need new bumpstops, especialy if you arent replacing the shocks. if you replace the shocks, then bumpstops are a good idea.
Dacaur
99 WJ Laredo
2.5" Budget boost, 265/75/16 tires, K&N air filter
Past Jeeps:
1992 YJ 4.0, 5 speed 6", lift 33's
1992 XJ 4.0, auto, 3" lift, 31's
1999 XJ 4.0, auto, 3" lift, 31's
1985 XJ 2.5, 5 speed, no lift, 255/70/15's
Dacaur is offline
Have 2.5" Wj Coil Lift, Whats Needed For 4.5" Lift JEEPGUY09 ZJ Grand Cherokee Forum 22 08-13-2009 08:24 AM
Will shocks from 89YJ with 4"lift fit 95 Grand with 2" lift? bunk1967 ZJ Grand Cherokee Forum 9 04-05-2009 12:21 PM
WJ Lift starting 2" BB and working up to 3" and eventually 5" SSnipes ZJ Grand Cherokee Forum 6 04-01-2009 02:02 PM
1st Azusa Trip with 4"super lift "Verdict" wccf91 WK Grand Cherokee & XK Commander Forum 4 07-16-2007 10:23 PM
