1st gear for hours at a time ok? - JeepForum.com
post #1 of 11 Old 07-13-2013, 02:44 AM Thread Starter
ErikTheRad
Like many of you, I use my Jeep almost exclusively for camping, towing, and trail driving. Often times while on the trails I drop the trans into 1st gear and leave it there while creeping up or down rougher terrain, sometimes for better than an hour at a time. I've not experienced any trouble so far but I know that doing this on some transmissions can stick a valve and cause shifting issues. Any problems doing this with the 46RH?
ErikTheRad is offline
post #2 of 11 Old 07-13-2013, 05:01 AM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
Nope
04 4.7 HO, limited
08 Z71 Suburban, front leveling kit with rear spacers. 285/65 18s Nitto TerraGrappler G2s
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
For your performance needs:
480.998.366
Texas ZJ1 is offline
post #3 of 11 Old 07-13-2013, 06:46 AM
newfieZJ
All I can see worrying about is keeping it cool . Maybe Tex can be more specific with his answer and change my mind , I've done it lots without any issue
1995 Orvis build
1988 MJ build
1998 Slate 5.9 build
1998 Platinum 5.9 build
newfieZJ is offline
post #4 of 11 Old 07-13-2013, 01:19 PM Thread Starter
ErikTheRad
I always keep an eye on temps, and my ZJ is equipped with the factory trans cooler (not heat-proof but it helps.) It never gets hot when creeping on the trails. I just wish I had a crawler gear because I do sometimes worry about the brakes on the long slow downhills.
post #5 of 11 Old 07-13-2013, 02:13 PM
PolkaPower
4lo keeps everything cooler than normal.
PolkaPower is offline
post #6 of 11 Old 07-13-2013, 03:18 PM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
Specific, the zj is designed to be shifted into 4lo and into 1st and left there for long periods of trail riding, rock crawling and mud digging.
The problem is that most zj drivers have never shifted their transfer cases.
Hunter
04 4.7 HO, limited
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
480.998.366
post #7 of 11 Old 07-13-2013, 06:19 PM Thread Starter
ErikTheRad
Mine is a NP249, I have yet to encounter a situation where I needed 4lo (which either means the 249 is THAT awesome or I only do sissy trails). Anyhow, the linkage for the 4lo is a mess, the cross-pin keeps falling out and I haven't yet rigged up a good fix for it. Thats next on the list after I get this damn right front suspension clunking thing figured out.
post #8 of 11 Old 07-13-2013, 06:20 PM Thread Starter
ErikTheRad
BTW, will dropping the transfer case into 4lo be more of a "crawler gear"?
post #9 of 11 Old 07-13-2013, 06:23 PM
PolkaPower
Yes, low speed and a lot more torque at low RPM's. It flows all of the oils and fluids at maximum to keep things cooler.
post #10 of 11 Old 07-14-2013, 05:00 AM Thread Starter
ErikTheRad
Cool. Guess I better get busy and fix the damn linkage issue so I can actually use my 4lo.
post #11 of 11 Old 07-14-2013, 07:41 PM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
Sir, that's the best thing I've heard in the last 3 mins.
Hunter
04 4.7 HO, limited
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
480.998.366
