1999 Limited Issues - JeepForum.com
post #1 of 8 Old 09-23-2009, 02:14 PM Thread Starter
sethfosho
1999 Limited Issues
I am goin to buy a 99 limited tomorrow. A heads up on any issues I need to look out for would be great!
thanks
sethfosho is offline
post #2 of 8 Old 09-23-2009, 02:57 PM
befumo
Since your in North Carolina im assuming no rust?
Check for transmission slippage, 4WD works. Basic stuff.
'89 YJ Wrangler - Sold
'95 ZJ Orvis Edition
'89 YJ Islander
befumo is offline
post #3 of 8 Old 09-23-2009, 04:36 PM
nick62087
I have a 99, most of the issues i have could probably be attributed to first model year type of stuff - some other issues may be due to neglect.
-My front driveshaft is the CV type, it was noisy as hell (newer models have u joints)
-When i leave the headlights in auto they flash on and off whenever they want to when the car is parked w/ teh key off (i hear they revised the switch in later model years)
-Heated seats work when they want to (there were a few recalls i think)
-Lights in overhead console dont work, lenses rattle when i drive
-My auto climate control works fine, but i hear many people have issues
-Power steering leaks
Theres probably more but i cant think of them. Id say just use common sense and make sure the thing is solid.
Good luck
nick62087 is offline
post #4 of 8 Old 09-23-2009, 05:47 PM
vtgrand
as befumo says make sure the tranny is in smooth working order. my sisters ended up needing some sensors, it wouldn't shift out of 2nd
vtgrand is offline
post #5 of 8 Old 09-23-2009, 05:58 PM
01Limited45324
Heated seats were a problem (mine, for example, don't work) in a LOT of WJs. Since it's a Limited, check the A/C and Heat, and see if you have the dreaded Blend Door problem.
Other than that, the usual (4WD, Tranny, etc.).
-Tom
2001 Grand Cherokee Limited
2002 BMW 530i
01Limited45324 is offline
post #6 of 8 Old 09-23-2009, 08:03 PM
Double E
Double E's Avatar
A member since 2006 and he's just now buying a 1999 WJ and visiting. Committed to the purchase already and then looking for advice....
Search! ....my NC state brethren.
Hell...look at my sig and you have half the story on the WJ.
Go back through 5 pages of posts and also wjjeeps.com and you're all set.
Welcome to the good WJ life and the chaos.
Pics please
'04 Freedom Edition HO & '04 Overland HO (previous '00 Laredo 4.7)
Double E is offline
post #7 of 8 Old 09-24-2009, 12:19 PM Thread Starter
sethfosho
haha..i actually had a TJ at first...sold it and got a 2004 WJ...that is for sales by the way...and just picked this 99 up today...ill try and get pics asap...work sucks...
post #8 of 8 Old 09-24-2009, 12:26 PM
Chatham036
master govener sensor. it is a cheap fix at least
1997 zj / K&N Cold Air Intake / 2"1/2 bb lift / AirAid Throttle body Spacer / 31x10.5x15 / Edge Throttle Body / Adj. Front/Rear T bars / Edge Chip / Gibson Header / HiFlow Cat / Custom bent exhaust w/ Thrush Turbo Muffler / Optima Yellow Top
Originally Posted by ef1992 View Post
The wheels REALLY can give you more hp???
Chatham036 is offline
1999 GC Limited ? UKSEC ZJ Grand Cherokee Forum 0 01-23-2010 06:46 AM
1999 JGC Limited tranny gone? marshallb754 ZJ Grand Cherokee Forum 5 12-19-2006 04:16 PM
ARB GRILL FOR 1999 JGC Limited skatingbo ZJ Grand Cherokee Forum 21 04-20-2006 04:32 PM
2000 WJ Limited vs. 1999 WJ Limited, which one? blizzboy283 ZJ Grand Cherokee Forum 7 10-04-2005 09:19 PM
1999 GC Limited any concerns? -Joe- ZJ Grand Cherokee Forum 7 07-03-2005 09:42 PM
