1999 Grand Cherokee - ABS light won't go off - JeepForum.com
post #1 of 9 Old 03-31-2008, 02:02 PM Thread Starter
plastic55
I own a 1999 Grand Cherokee Limited. The ABS light will not shut off and I do not get an error code when I turn the key back and forth a couple of times. The odometer reads "Done" signifying there are no problems.
Any suggestions?
plastic55 is offline
post #2 of 9 Old 03-31-2008, 03:03 PM
WJChris
WJChris's Avatar
ABS computer is seperate.. right?
Check for dirt around the sensors at your axles. I think you should find them just inboard of the rotors.
WJChris is offline
post #3 of 9 Old 03-31-2008, 03:08 PM
BlaineWasHere
BecauseRacecar
BlaineWasHere's Avatar
It's a long shot, but check the ABS fuse too.
2013 FR-S
BlaineWasHere is offline
post #4 of 9 Old 03-31-2008, 03:13 PM
MuddyLuxury
MuddyLuxury's Avatar
pull the bulb and be done with it, as long as your jeep is shifting right and the speedo works, kill the bulb and be happy
-Jeb
99 WJ 4.7V8 selc-trac swap
285s re-tread
IRO 6.5 Long Arms
Aussie Locked Rear
in the works... lots deployments are great for jeep budgets
Go Doorless!
Things i need..
good spots in the mid atlantic to camp, hike, fish, kyak and wheel, if you know please share
Originally Posted by 5.9 ANDY
i would do the rear.
MuddyLuxury is offline
post #5 of 9 Old 03-31-2008, 03:15 PM
BlaineWasHere
BecauseRacecar
some people WANT ABS....
My GTI has so much braking power even during a panic stop I have yet to get the ABS to kick in. Jus to make sure it worked I put the pedal to the floor going 70...
2013 FR-S
post #6 of 9 Old 03-31-2008, 04:37 PM
WJChris
WJChris's Avatar
Thats all TIRES and weak braking power, Blaine. If you had sooo much braking power, you would lock up easily...
WJChris is offline
post #7 of 9 Old 03-31-2008, 04:40 PM
indept
I had the same thing last August with my 2000 WJ. I went to the dealer & paid 45.00 to get the codes since you can only read them with the DRBIII or equivalent. A standard OBDII reader or the key method doesn't work for ABS. They said it was left front & right rear sensor and the abs motor was bad too. I went home & measured the sensors with an ohmmeter but I found you can't check these sensors that way, so then I disconnected the pos battery terminal then disconnected the connector from the ABS computer, made sure there were no recessed pins or broken wires, reconnected it, reconnected the battery. The light was out and the ABS has worked fine since then.
2000 WJ 4.0L 42RE 242 TC
190,091 miles & counting
indept is offline
post #8 of 9 Old 03-31-2008, 09:36 PM
BlaineWasHere
BecauseRacecar
Its a combination. Think about why racecars have 6-piston calipers. The stickyer the tires the more force your brakes can use.
2013 FR-S
post #9 of 9 Old 03-31-2008, 09:46 PM
QuadraTokn
QuadraTokn's Avatar
1930 WJ
The key trick and ODBII scanner only work for the CEL/MIL. the ABS codes require a special $5000+ machine to read the codes.
NEW Dana 44a Axle Truss and Skid !
WJ Grand Cherokee Tube Doors For Sale !
ZJ Grand Cherokee Tube Doors For Sale !
PARTS FOR SALE from 10 WJ Grand Cherokees ! !
QuadraTokn is offline
1998 grand Cherokee 5.9 vs 1999 Cherokee 4.7 rrich49132 ZJ Grand Cherokee Forum 89 11-27-2010 07:11 PM
1999 Grand Cherokee - Security Light Brian-Noll ZJ Grand Cherokee Forum 19 07-17-2008 12:36 PM
1999 Grand Cherokee Wierd Light Problem hawknose ZJ Grand Cherokee Forum 1 06-18-2007 11:03 AM
1999 Grand Cherokee 4wd Question hurstrescue ZJ Grand Cherokee Forum 8 08-18-2006 05:38 PM
1999 Grand Cherokee Humming agave60 ZJ Grand Cherokee Forum 2 11-19-2004 05:56 PM
