1999 4.0 cranks no start no codes no spark? - JeepForum.com
post #1 of 8 Old 05-25-2009, 07:32 AM Thread Starter
relentlessmx
This is my dad's 1999 ZJ with a 4.0. Ran perfectly yesterday, when he parked it in the garage.
Today it cranks & cranks, but doesn't fire.
There is no check engine light on.
I scanned it (think I did it right, virgin scanner) no codes.
I pulled off the spark plug rail & checked for spark at two of the boots, nothing.
Even though my dad knows nothing about cars, he's pretty sure I'm an idiot. That would make this so gratifying to fix...
I'm thinking Crank Position Sensor, any thoughts?
Is there a way to test the CPS prior to swapping it?
relentlessmx is offline
post #2 of 8 Old 05-25-2009, 07:48 AM
gatorayde
Probably a CPS, at least that would be my guess. If it's a 99, it's called a WJ, not ZJ; just FYI.
gatorayde is offline
post #3 of 8 Old 05-25-2009, 08:01 AM
LalanP111
also might want to try the ignition coil, had mine go bad and it did the same thing, cranked but wouldnt fire
1998 TJ, 4.0L, RC 2.5", 31x10.5-15 Duratracs (sold)
1988 MJ, 4.0L ..soon for be on 33's and 6.5" LA/SOA (project)
2004 TJ, 4.0L, Columbia Edition, 2.5" Rough Country, 33x12.5-15 Duratracs, Quadratec Winch, Dual Top (DD, future project)
Originally Posted by Knuckelhead View Post
It takes care of me and in return, I take care of it. Takes me away from everything I don't want to be around, and back again when needed...
LalanP111 is offline
post #4 of 8 Old 05-25-2009, 08:30 AM Thread Starter
relentlessmx
Is there a way to test Crank position sensors, cam position sensors, and coil packs prior to replacing stuff randomly?
post #5 of 8 Old 05-25-2009, 10:32 AM
StellaTheZJ
Yes there are resistance tests in the FSM. I don't have any info for a WJ (anyone else), but if you google it, they're out there... I understand the CPS usually gives some warning before failing though. Has this truck been getting harder and harder to start, particularly when warm?
It's really unlikely all 6 coils would fail at once, so you're looking for something in common for all of them. Check all the fuses and relays (does the WJ have an ASD?) are free of corrosion on their legs, confirm the alarm is off, make sure there's voltage at the wires TO the coil pack, etc...
Good luck!
StellaTheZJ is offline
post #6 of 8 Old 05-25-2009, 05:54 PM Thread Starter
relentlessmx
All fixed... Was the crank position sensor. I had to remove the shift linkage for the trans and use a 18" extension to get at the bolt, took about 2 hours to get 1 bolt out SWEET design!
post #7 of 8 Old 05-25-2009, 06:09 PM
bcollier1823
Gotta love Jeep.
Billy Collier
bcollier1823 is offline
post #8 of 8 Old 05-28-2009, 04:57 PM
StellaTheZJ
Ever work on a Toyota? Try removing the intake manifold to get the fuel filter, which should be changed a lot more often than a CPS!!
Try removing the cross member under the tranny next time. If you lower the tranny a bit, the extra room makes the CPS more accessible.
4.0 cranks but does not turn after changing spark plugs and wires spencerk73 ZJ Grand Cherokee Forum 3 12-22-2009 11:22 PM
4.0 cranks but does not fire have fuel pressure at rail but no spark from the coil 98whtgcl ZJ Grand Cherokee Forum 4 09-10-2009 11:34 AM
sometimes my 98 zy cranks for 3 sec b4 start Kingair Pilot ZJ Grand Cherokee Forum 3 04-22-2009 03:02 PM
Jeep cranks cranks but just cant start ManUtd4Life ZJ Grand Cherokee Forum 5 06-04-2007 10:05 AM
1999 JGC 4.7L wj Sptting out codes ? skatingbo ZJ Grand Cherokee Forum 4 01-07-2007 01:32 PM
